PDA
View Full Version : 5.0/5.8 Engine-Stock
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20
  1. Converting to Carb
  2. 1986 Mercury Grand Marquis dies when idling.. please help!!!
  3. Trani Seal Leakin
  4. weird noise coming from under the glove box...
  5. My Gas Mileage sucks
  6. I believe I have an issue
  7. Questions I have about my HO
  8. Lincoln LSC Headers
  9. starter clicks
  10. Original AOD?
  11. Made a CAI and some perdying up under the hood (pics)
  12. Ford Dealership took my Spark Output Signal(Spout) out... ugh
  13. Engine...
  14. holley choke, 12v source? 80 lincoln
  15. 87 head question
  16. it finally happened
  17. No start
  18. Random carburetor annoyances
  19. Power steering pump leaking
  20. adding P/S fluid?
  21. Gas tank question
  22. life expectancy of aluminum heads.
  23. 88 Lincoln TC Temp Gauge Question
  24. Build Idea Discussion
  25. Failed Smog Check! Noooooo!
  26. cooling system upgrades are coming !
  27. Flowtech Headers ??
  28. engine light question
  29. tranny not shifting
  30. Whats the timing these motors are set on?
  31. My engine
  32. cam selection
  33. Different Types of Fuel Injectors.
  34. Mustang shorties, H-pipe, flowmaster muffler dual exhaust install
  35. Brake rotors for my Lincoln
  36. flywheel rattle
  37. Where to find Axle Code...?
  38. CFI guru-ism
  39. Things I'm learning about Holley carburetors
  40. TPS and battery
  41. Gas tank questions
  42. Engine replacement thread.... Pictures!
  43. oil sending unit extensions
  44. Vacume hose
  45. Transmission Fluid Leak!?!?!
  46. crank bearings
  47. 5.0 Mustang question
  48. Transmission Cooler
  49. Simple carb swap
  50. Fuel Injection tools
  51. Maybe crazy idea - box body on newer chasis
  52. Anyone ever mod a LoPo upper intake+TB?
  53. Intermittent Idling Issues
  54. Thermostat/Water Temp Guage
  55. Fuel Tank Overpressurizing
  56. blown head gasket
  57. Fuel door Q
  58. Celebrated the 4th of July by working on the car!!!
  59. As I save for my Duals, I'm wondering....
  60. Small Header problem
  61. cfi to efi ho
  62. Freshening up a Bronco 5.0
  63. Long block HO VS upgrading LOPO
  64. The new 5.0. H.O.!!!!
  65. 5.0L HO issues...still
  66. test connector
  67. coolant leak
  68. AOD transmision trouble
  69. talking to a local mechanic
  70. gt40 valve spring info needed
  71. Valve Seat Material
  72. HO CFI Cam?
  73. Power steering pump rebuild AKA new seals
  74. New flowmaster 44 dumped duals...
  75. Sealed Power OE replacement cam trivia
  76. Cap and Rotor..?
  77. Hose Sizes?
  78. painting engine components?
  79. Mini starter install
  80. AC belt help
  81. Brake pedal assy
  82. Mark 7 saga continues
  83. replaced your fuel filter lately?
  84. quick header question
  85. Help! Electrical Gremlin has made my '84 MGM its new home!
  86. what duals are you using?
  87. In theory
  88. Antifreeze in the oil...
  89. headers for stock motor
  90. Edelbrock 3781 and VV Carb???
  91. fly wheel or something else
  92. 91 Vic Odometer not working
  93. cork oil pan gasket?
  94. Roller Rockers Q
  95. Hesitation on accel - closed loop to open loop transition
  96. Crank No Start has spark
  97. Batrey question
  98. Losing coolant.....somewhere.....
  99. carb swap what do u need
  100. which size glasspacks?
  101. gas leak
  102. Just got a 88 marquis LS. What should i do first?
  103. Help! Engine Hissing sound.
  104. I have a hole in my transmission!
  105. herd ya guys talk about codes... how do i check them
  106. Temporary state of TOTAL panic
  107. Would a '92 F150 be of any use?
  108. Seeking more power, need suggestions
  109. help make my 88 safe for 14 thousand feet
  110. Sudden loss of power
  111. Rear Oil Pan
  112. Hard miss when pulling hills
  113. No tach??? Trouble code says I have no tach
  114. let the stroker live
  115. New mufflers on the 91....
  116. whats code 33??
  117. Super Unknown ... blown head gasket?
  118. Allrighty Some probs...
  119. AOD gear slip
  120. 89 lincoln town car cutting out when warm
  121. Carbed 351 HELP please!!!!
  122. Do I Need to Bore Our The EGR Plate
  123. O2 sensor test.
  124. So I finally hooked up the code-reader....
  125. A coupleof problems
  126. Alternator Wiring
  127. H pipe
  128. Well my gas mileage has tanked...(well has decreased)
  129. BUILD UP IDEA-COMMENTS PLEASE
  130. When making a turn...and the car bogs/hesitate...
  131. Steering gear swap
  132. What Fuel Line Type................
  133. external fuel pump ?s
  134. AOD kickdown cable
  135. Did box town cars get different cats?
  136. would you buy this oil filter
  137. RIP AOD - what now?
  138. just a dream
  139. hoses
  140. water = check engine light?
  141. exhaust pipes leaking!
  142. Some questions on LOPO upgrades...
  143. ECU's
  144. Drain plug seal/gasket questions
  145. Pinging under light load, goes away with more throttle?
  146. A.C. Help.....
  147. New electric water pump for 5.0
  148. Engine light on dash flickering when revs drop low?
  149. Do I need to adjust the valve lifters or are they automatic?
  150. Engine Break-In
  151. Vac. advance VS. no vac. advance?
  152. I think I blew something up!
  153. Oil pressure sending unit question
  154. code 77? Goose test? + awfull gas mileage
  155. Oil leaking out of the top of the dipstick tube
  156. Ticking noise in drive-thru
  157. No check engine light in my TC?
  158. More cooling system issues
  159. Cheap HO parts score !!
  160. So I went to my car the other day and I started it up and put it in d and it stalled
  161. Half HO swap
  162. Oil in air intake tube.???
  163. Need explorer cam specs
  164. What is this thing/what did I just fix?
  165. Feels like air in the Hoses
  166. Oxygen sensor on headers
  167. Stock 351w 4bbl intake
  168. Transmission Leak
  169. 83-85 CVPI
  170. things that could stand to be replaced
  171. Strange high idle
  172. What Engine Should I go with?
  173. Random miss fire?
  174. 5.0 block question
  175. 87 mustang gt motor
  176. fuel tank leak
  177. Beginning Explorer Swap
  178. Coolant Leak / Missing Bolt?!?!?!
  179. New intake! And a bunch of other goodies
  180. strange hot rod rumbling?!?! when in OD D 1?!?!
  181. Putting a Super Charger on to a Crown Vic or Merc...
  182. Pedestal or Stud Mounted Rockers???
  183. Hmm, I think I found the miss.
  184. Distributer Gear
  185. 94 Mustang GT 5.0
  186. Mass Air Flow Conversion
  187. Mass Air or HO conversion
  188. warm up?
  189. Distributor cap musings
  190. car swaying at idle after long run
  191. deleting the cats
  192. Alternator Belt Noise
  193. Will Mustang Unequal Shorty Headers fit?
  194. Temporary brake line fix?
  195. synthetic oil, yay or nay?
  196. Car boggs Down, and doesn't want to go over 30 mph
  197. Changine the fuel pump in a wagon without dropping the tank.
  198. A/C Pic Request
  199. I don't know where to put this.
  200. Flywheel/flexplate weight on the 5.0?
  201. wiring harness questions
  202. Nitrous CFI in the Works!
  203. More 351W Questions?
  204. 1 second engine light
  205. Catalytic converter prices
  206. Cam and valve spring selection?
  207. 1991 351w Timing....
  208. 1.7 Rocker arms
  209. oil cooler
  210. cat-back exhaust question
  211. Noob Header ?
  212. Which Shift Kit?
  213. '88 town car trouble codes
  214. Engine Light Question...
  215. mufflers
  216. Finally got my gears in.....
  217. Garbage idle
  218. Nitrous Installed!!
  219. Explorer P heads...
  220. intermittent check engine light
  221. Oil in MAP Hose
  222. Has anyone had this happen?
  223. OK to drive with TPS off?
  224. EEC-IV 2 digit trouble codes
  225. stupid question- spark plugs
  226. running rich
  227. Advance the cam ???
  228. Fuel rail question
  229. Oil leaking
  230. crappy gas milage
  231. 85 vic won't start
  232. HELP! No Fuel Injection on Cylinder 7
  233. EFI Intake/Throttle body info
  234. Free Comp Cams "CamQuest" software
  235. steps for installing duals
  236. Idle over heat
  237. weird voodoo
  238. how to remove fuel rail?
  239. Exhaust Question
  240. Goo in my oil
  241. Problems with 3g alternator
  242. Cam Question
  243. replacement for stock airbox?
  244. Noisey engine accessories?
  245. ps pump replacement
  246. Have to give it gas to start it.
  247. Fuel regulator
  248. Fuel Injectors
  249. What headers do I need???
  250. new radiator
