View Full Version : 5.0/5.8 Engine-Stock
Pages :
1
2
3]
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
- heads!
- Furthermore proof that our tech is MUCH better...
- Well maybe it wasn't an Alternator
- Bushings
- its time to rebuild the towncar's engine help?
- new have gm but looking at mustang
- Mods - label the good stuff!
- correct speedometer gear
- {ELECTRIC} alternator - I am I overlooking something?
- Carb rebuild tonight... sorta...
- TransGo shift kit has arrived! (Thanks Eric)
- my towncar keeps overheatin
- One step closer.
- 8.8 Install page...
- Propane conversion
- quick tranny question
- right turn signal is sticking
- i'm scared
- A/C job a flop ::rolleyes::
- Heater Core Hoses
- exhaust plans
- Towing Capability
- friggin Advance Auto crap
- '91 ignition switch?
- Trunk release solenoid bad?
- How long to swap evaporator cores?
- Emmisions help!
- Wierd...
- AOD
- a/c fan wont work!
- Trunk tension rods
- Car will cut off periodically
- good weekend, engine striped down =)
- stumbles when letting off gas
- Exhaust?
- Talk to me about rear springs
- engine parts list muhahaha
- anyon use an explorer intake upper lower and throttle body
- blue smoke, what's it mean?
- type f instead of a shift kit?
- head to ho intake gasket vs heat to gt40 intake gasket
- Idle
- few problems, Stalling..
- HELP KRASNY... Yeah...
- Turbines, BAHH!!!!
- No second gear???
- im an indecisive bastard. 347 stroker?
- got sludge???
- Rear end vibration
- polyurethane bushings?
- 4 PIPES AM I GAINING POWER OR LOSEING POWER
- Will these work
- Cleveland or Windsor 351
- How are misfires detected in OBD-II ?
- OVERDRIVE IS ACTING FUNNY
- Project: Ultimate Daily Driver, Underway
- Electric fans...who's done it?
- OK, exhaust time
- Question about rad hose
- brake swap parts
- Stupid injector question.
- possible over-heating problem
- rear 3.73 gears
- Gas-cap flow by?
- Perforance upgrades + MPG
- Just installed a Tach
- Alternator suggestion
- Fox mustang exhaust
- possible new motor for my build up
- ratchet shifter - - anyone done it?
- wheelbase differences?
- is this an EEC i can use for HO convo?
- Headers.
- can i get a shift kit for a towncar?
- hmm...
- Cobra TC big brake/disc conversion chronicle
- 125K...
- Header pics
- Head lights wont come on again...
- New windshield finnally....
- New Tires!
- P-R-N-OD-D-2, should I drive in "D"?
- Cold air intakes
- Police Car Junk Yard Special
- 140 mph speedometer
- shift kit... accm help...
- What the??
- Help Tranny shifting
- HO Cam + 1.7RR ?
- leave it to me...
- Wondering about injectors?
- how do you install a tachometer?
- Stock compression Vs. 11.0:1
- Code 54
- Air pump...
- 1990 Town Car Header Pics - Performance Question
- Holley TBI Unit
- how do you get off stubborn gasket material
- Here are some nice headers...
- Which AOD shift kit equals the J-Mod for the AODE?
- My car is Possessed!! Please help!!! IF YOU CAN
- buy my parts.... please !!!
- is a used cam worthless without its matching lifters?????
- wheel alignment -- question
- bought a motor today
- Rod/Main bearing undersize??
- will a F-150 5.0 HO computer work on my towncar
- How to add hp to a worn out engine :)
- new car checklist
- Speed Density Question
- temp gauge question
- Emergency ball joint replacement
- Amp Gauge hookup????
- Variable Venturi Replacement.
- Well, those didn't last long.
- pimples!
- Tranny rebuild time.
- What's the 1st mod for a bone stock car?
- Anybody have a computer?
- underdrive pulley!!!! :)
- Explorer computer?
- 347ci stroker
- Radio mount finished....
- just started my HO conversion already broke 2 things
- non-HO cams
- Code 74
- timing chain replacement
- Possible Dual Exhaust Kits??
- annoying wiper noises
- Tailgate
- door switches: avaliable still?
- where to get heads rebuilt
- Heads
- replacing injectors, need help!!
- Gun Rack, and other rants!
- Should I switch back to 10w30 for winter months?
- Dimensional Analysis - Speedometer
- Windshield Wiper Motor
- thunderbird 5.0 headers better?
- The IAC and me
- '91 with a drinking problem
- Shuddering
- Score !!!
- New shifter
- Tips on working on a 5.0?
- {Electrical} 3G swap
- random question
- questions about getting shafted
- Latest on the 84....
- Red hot headers
- Synthetic
- New radiator
- timing questions
- where to run temp and oil psi guage lines
- WhooHoo
- My carb is FuXored
- AOD question
- water pump differences (picture)
- More police package questions -VIN related
- Stupid question
- Nice Mass Air write up
- 2150 finally shit teh bed...
- Equal Length Shorty Headers?
- Five Oh wont Go
- HO Throttle body mod questions
- A better 2BBL intake?
- 2000 mustang gt vs 88 gm gs
- For those wanting to use an explorer motor...
- Intake spacer worth the money?
- motor swapping
- I pulled my motor ......
- Dash pads.
- how much did you notice your HO conversion
- Backpressure
- badass towncar for sale
- anyone know the GVW of a 1989 townie?
- Air pump...
- Ryan's CV kicks ass
- trac-lock and exhaust q's
- removing the egr valve
- TRANNY TAG
- 4bbl swap, happening tommarow!
- Idler pulley...
- Updated: REinstalled 3.27 ring/pinion
- speedometer gear question.
- Exhaust day
- Did something really dumb.
- seat belt retractor
- Engine building walk-through
- frickin junk parts
- Explorer Part Pics
- 4bbls of fury!!
- Roller cam blocks
- Raw Picture Site is Up
- GT-40P Headers
- tips on keeping block clean
- Got these parts and more for $40 bucks **pics**
- Looks like i need to get the lokar kit.
- freaken TV linkage
- Quarter mile times
- Sorry, a tempo question
- this sucks
- crank bolt is REALLY stuck on
- New wires! *DUW*
- Spark knock problem???
- Manual Valvebodies
- What do you think? (daytime pic)
- Longtube header install, part one.
- 88 vic stock 302
- Turn signal issues?
- 2000 mustang gt vs. 88 gm gs
- broken head bolt: 0, Me: 1
- Rear gears - what do I have?
- Oil pump replacement - Motor still in car
- injector question
- '87 Cougar - charging issues (EFI 302)
- Marquis + TC Rear Clip?
- Heads?
- Top speeds for our cars.
- changing differential oil
- timing adjustment?????
- Longtubes... Part two. *DUW*
- Sway bar Bushing Squeak???
- cylinder head bolt torque
- AOD Problem
- CAI for a 302?
- {Fuel System} Replaced my Fuel Pump.
- 85 Merk
- Update on HO conversion
- 87 2 dr
- {ENGINE} Oilpump replacement, in the car..
- gauge set-ups
- HO swap question
- Oil leak...
- Carb conversion update...
- What do i have??
- SHES ALIVE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- WILL A H.O. CAM WORK WITH CFI SYSTEM?
- electrical gremlin!!! (UPDATE)
- governer
- ROUGH IDLE
- will this work?
- Tuning SD for extensive mods.
- Longtubes...
- just bought these
- 4-Speed Swap?
- Suspension question...
- idle probs
- 4bbl swap-Update..
- Coil mounting location??
