- aod tv cable adjustment info
- Frankenstein T-5 Waggin' Chronicle (vast doesnt do it)
- low RPM shudder, clunky overdrive
- The Panther T5 Swap...
- Panther/3 on a tree project ;)
- AOD valve body interchangablilty
- shift kit - educate me
- Wide Ratio and B&M Vs Trans Go
- 3 speed auto to 4 ...
- Another AOD question.
- Valve body question
- Manual Transmissions
- AOD fluid levels
- S.U. - transmission rebuild/replacement
- '89 CV -- slipping trans
- t56?
- Pre-Prep on AOD replacement
- Trans Question...
- getting transmission rebuilt...have ??????
- recommended trans cooler?
- Tranny Leaking
- With all the Trans mods I'm doing...
- reverse ratio 1989 Ford AOD?
- "A" servo...shift kit...or both???
- I feel dumb for asking this question but where is the tv rod?
- Tranny Cooler Goodness
- torque converter for wide ratio AOD?
- Tranny Extraction
- My opinion of the Jasper trans
- WR AOD and Shift Kit questions...
- Borg Warner T5?
- Transmission fluid
- Transmission Install questions
- Tranny whine and tranny coolers
- Tranny problems
- Mustang AOD
- MAGNA's AOD Buildup
- AOD vibration
- TV Cable
- Transmission going out?
- ATF in a Manual Transmission?
- changing shift rpms
- need advice on AOD governor
- Clutch Kit differences between '89 and '90?
- C4 transmission - shift linkage and shift points
- governor upgrade options?
- quick trans question.
- Another Tranny Q
- C4 for an AOD
- How to adjust TV Pressure with pressure gauge
- Stick-shift conversion?
- C-4
- Couple problems
- aod choices
- Tranny Problem
- valvebody
- I have decided to have Vicky's Transmission Rebuilt
- OD gone on my AOD
- Shift linkage bushing(s)
- mustang T-5
- want to swap an AOD into my 79, please help the noob!!!
- proking kit
- '83 and '88 AOD linkages the same?
- Flushing Transmission Cooler
- AOD Trans Slipping
- Type F in a AOD?
- To Change or Not To Change: Tranny Fluid
- Tranny not shifting...?
- my TV grommet ripped..
- how to drain ALL the tranny fluid?
- Some questions on a 4r70w swap in a box?
- Push Button Transmission
- TRANSMISSIONS!!
- would a c6 or e40d fit?
- aod output shaft-driveshaft yoke spline count?
- converters and govenors
- speedo gear/governor/rev limiter locations??
- wide ratio vs stock
- Manually shift an AOD? (normal driving)
- Should I change the trans fluid?
- TV bushing and what else? (pics)
- AOD question (is it DOA?)
- Weird 4->3 downshift issue.
- C4 conversion, Linkage ??
- Transmission noise
- Help with TV cables!
- tranismission problems
- dying transmission (OD band?)
- What is a good shift kit for a noob to transmissions?
- Any one dealt with 1stoptransmission
- Transmission Question
- B&M Shift Improver Kit
- Reverse clutch piston return spring
- No Overdrive in '89 Town Car
- installing trans-go NOYOYO shift kit...
- C6 to AOD swap
- Cost to Beef up AOD/4r70w vs. TCI AOD
- AOD 1st to 2nd to 3rd too fast
- Speedo gear removal
- Shift points
- aod rebuild
- speedo
- Started Tranny swap
- getting the AOD tranny beefed up...
- OD Shifting question
- Transmission w/60k, flush or not?
- Trans dip stick is gone!
- Which one is the TV test port?
- aod not shifting
- Transmission pan leaking
- 89 vic t-5 swaped issues
- AOD vs. 4R70W
- Hard Shift
- Just a quick question
- HOW does failed tv bushing kill trans?
- AOD '83 vs 87-91
- tv cable help
- AOD Help
- aod tv cable/rod help
- What tranny fluid should I use?
- Tranny Service Procedure
- :( :( :( Transmission???
- loosing the aod?
- 1984 Towncar Transmission Slips from 1st to 2nd
- Finally i found a way on how to get rid of AOD Shuffle.
- AOD Wide ratio parts list.
- 1 piece input shaft source?
- AOD valve body upgrades
- Floor Shifter
- Play by Play AOD Removal
- Once again TV cable
- TV pressure, how much?
- compatible transmission mounts?
- Good friday is transmission day
- trans fluid level?
- Speedometer Gears
- having an issue with my tranny linkages.
- Auto Transmission Dimensions
- 1980c10's T5 swap with hydraulic clutch
- 1989 MGM 69000 Transmission Slipping when cold
- AOD slipping on 1-2 shift and on right turns
- Think Im going for it...
- 91 Merc Grand Marquis won't start or run in park. Will start in neutral but stalls
- Wierd difference in new/used transmission
- Used 'Stang AOD
- how much would you expect to pay
- Police valve body shift kit?
- clunking/grinding
- Will it fit?
- T5 Time is Now.
- 1990 Town Car Vs. 1989 Colony Park transmission
- Strange hole at the end of the transmission
- Does the TV bushing go on top or bottom?
- Manual 4r70w
- wide ratio swap? and other trans improvements. respond soon (ordering parts)!
- Good place for trans parts
- what does "adjusting bands" mean for a transmission?
- Merc/Ford and Lincoln AOD differences
- Prepping a used AOD for installation?
- kickdown feature is broken?
- gaps in understanding of tv cable's effect on line pressure?
- can a transmission slip without perceived flares?
- the AOD of suckage
- possible stupid question but have to know.
- tci constant pressure kit?
- will this atf work
- transgo street/strip kit
- 86 cp tv adjustment?
- Possible to add a 3 on the tree?
- Speedo Gears
- What possible donor cars for a '90 GM transmission.
- Valve Body
- aod or c4 question
- Transmission Slipping...Suggestions?
- Changing fluid
- harvesting wide ratio aod parts
- 86' TV Cable Replacement Options
- Transmission Mount
- Barf: my AOD rebuild that runs perfectly except delay in reverse WTF??
- good transmission brand
- 1989 Grand Marquis GS - shudders and jerking problem
- TV Cable tb Bushing Source
- '86 tc trans
- Speedo Leakage
- 1989 Lincoln not shifting into overdrivre
- Aod Trans flush Confusion
- Any ideas
- aod build quote
- Changing fluid: is it worth it?
- aod wr conversion questions..
