PDA
View Full Version : Box Panther Performance
Pages : [1] 2
  1. you think these headers will fit?
  2. 429/460/514/528
  3. Super Unknown -- 350 HP 302
  4. reason why full length headers won't fit?
  5. how far can a 302 go before it blows up?
  6. The wa-gone plans
  7. HO Conversion - Mike's Tips and FAQ
  8. Recipe for 427 cubes
  9. i had a dream - efi 347 stroker
  10. Commentary on the offical timeslip thread
  11. My first step toward 300+ HP....
  12. 12's or less ...
  13. Slydawg in the 13's!
  14. New Best Time
  15. New In-Car Track Video
  16. Large Car Race Event
  17. Wishful thinking...
  18. OK you all know that I am..
  19. OK gonna need some info
  20. Harvester of Sorrow begins...UPDATED 6/16 *PICS*DUW*
  21. Big Block Techie stuff
  22. Lincoln Crank
  23. Does anyone here have...
  24. New Pics
  25. Anyone Know what Oil Pan
  26. Getting track ready...
  27. 351 Build
  28. Frankenstein Wagon Chronicle Part II
  29. NHRA Division 2 Finals from Cecil, Georgia
  30. Extreme Makeover: Big Tank Edition (#1)
  31. Extreme Makeover: Big Tank Edition (#2)
  32. Update: Good & Bad News
  33. Pics of new paint & blown motor
  34. The Official GMN Exhaust Size Thread
  35. 390 question?
  36. Back on the track...
  37. name my parts.
  38. Plans for Anabelle
  39. I said F it and spent the $$
  40. Tuning the beast...
  41. desktop dyno stuff
  42. Hitting the dyno tomorrow...
  43. getting a towncar into the 11's
  44. NEED HELP!
  45. Piotr's 359ci Windsor Build
  46. someone is goin turbo
  47. Engine Questions
  48. Twin turbo 351W box...
  49. Whaddya Use To Cool Your CVs?
  50. anybody run "twisted wedge"?
  51. Mod Motor Box Madness
  52. Cleveland powered box?
  53. If you haven't been on CVN lately..
  54. EFI 351W build
  55. dyno
  56. Small Block Windsor Full Length Headers
  57. 351 Windsor build
  58. The 351W Long-Rod Thread of Doom.
  59. Street Driving with a Dominator
  60. aftermarket front race brakes
  61. High Volume/High Output Water Pumps
  62. Diesel --> Towncar
  63. Curious about few things....
  64. HO TB swap w/ bored stock spacer
  65. Time to start spending money
  66. Oh well I had to do it....
  67. Anabelle's new engine
  68. More tweaking with the TwEECer
  69. Well my dream is coming true!
  70. 460 in a Box
  71. TwEECer RT on Speed Density
  72. Something new that Trick Flow Specialties is working on....
  73. I want to supercharge the LSS
  74. 400.....Modified.
  75. gt40 motor and mark VII ecu problems
  76. Dyno in Harrsiburg
  77. 5.0 HO versus Explorer Motor
  78. 351 swap intake thoughts
  79. Marauder/CVPI airbox, in a box
  80. Twin turbo 306 Towncar
  81. Chevy 350 in a Panther?
  82. New-ish head from Edelbrock....
  83. What cam should I go with?
  84. Need help with build options
  85. Fuel line routing ?
  86. Will this supercharger work?? I saw it on corral and idk looked better for box setups
  87. What could improve this setup?
  88. Tell me your thoughts.
  89. upgrading valvetrain
  90. Found a nice link on the 385 460's...
  91. Sump location
  92. 351 BBk headers
  93. What do I need to...
  94. How Much Can a Lopo Take?
  95. Estimated 1/4 with the following parts?
  96. 350-385 HP explorer motor
  97. what would a complete HO roller motor be worth?
  98. Getting Ready to do my build on my crown what else should i get...
  99. Need some advice.
  100. camshaft question
  101. HAHA CAMS AGAIN
  102. Looking at some crate motors...
  103. Engine Terms and Stroker explained
  104. Long tube headers
  105. Cherrybomb glasspacks (sausage shape)
  106. Exhaust pipe length/ over axle?
  107. TFS Cams
  108. Fuel Injector Sex
  109. some cam info i came across
  110. 5.8 Swap in the works, questions.
  111. 87-93 HO intake/TB + stock EGR?
  112. going to a carbed 351 in august...questions
  113. How do these combos sound?
  114. header install price
  115. what yall think?? elderbrock600 carb &intake 302 in 84 crownvic
  116. Big block in the future??
  117. Hows my summit tune up/header/hpipe shopping cart?
  118. My 88 Grand Marquis.........Upgrades?
  119. 302 carb..help me out
  120. Air injection pipe
  121. Roller Cams
  122. performance modification thread
  123. more XE258 cam quotes and other cam stuff
  124. Bolt in megasquirt
  125. HO Mustang Intake Plenum Spacer...Worth it?
  126. Lincoln Logs (Tubular exhaust manifolds)
  127. Exhaust Question
  128. Cams and torque
  129. Poor Gas Mileage
  130. testing injectors?
  131. e6/e7 heads and torque
  132. Carb spacers?
  133. Plugs, so many different plugs!!
  134. what else to do during HO swap
  135. Swap complete 2 big bugs
  136. throttle body
  137. hypothetical fuel economy / power build ideas
  138. Still having problems, what to do
  139. doing GT40P swap soon... questions
  140. lightning egr spacer?
  141. 4.6 in a Box...
  142. Finishing up Explorer 5.0 build
  143. help with 351w swap
  144. storing camshaft?
  145. First Impression, Road Testing
  146. Need help with GT40 intake bracket mounting
  147. Oil cap wont fit with HO valve covers and GT40 intake
  148. Another question I couldn't answer!
  149. Completed HO engine swap pics (finally)
  150. What throttle position sensors fit Explorer 65mm throttle body?
  151. Wiring pinout question 1989 Town Car
  152. Shift light for the marq
  153. Aluminum Radiators
  154. adj fuel pressure reg not changing pressure
  155. header install for dummies
  156. annoying oil drip
  157. mass air wiring question...
  158. V-10 in a Wagon
  159. compatible exhaust?
  160. Underdrive Pulleys Junkyard Style
  161. swap done, small issues...
  162. Buddy Needs YOUR Help Making an '86 Tudor Marauder!
  163. Ideas to lose weight and look stock
  164. advancing HO cam powerband change?
  165. Optimal Tunning
  166. Just an update on my motor build...
  167. 1990 TC MAF conversion questions
  168. Exhaust Question
  169. Fuel Line Sizing?
  170. X-Pipe options on '90 TC
  171. Exhaust is done!
  172. Timing Gears?
  173. A Tale Of Two Cylinder Heads.
  174. My motor has a riddle for ya's...head issues...
  175. nitrous system almost complete
  176. EDIS Distributorless Ignition Conversion
  177. Pics of Nitrous System
  178. 2.5" exhaust install - '88 GM
  179. coolant bypassing EGR spacer?
  180. explorer throttle body setup
  181. yeah, another exhaust combo thread. deal with it.
  182. egr to tb gasket
  183. 351 heads
  184. boring out a block
  185. best readily available 302 to start with
  186. article on gt40 intake swap
  187. GT40p, Lincoln Logs and #5 plug
  188. Comp XE258 cam fits...
  189. 460
  190. 5 speed
  191. 1979 Marquis 7.1 Will It Fit?
  192. fuel pump upgrade?
  193. 351 Cleveland swap?
  194. building a bottom end for nitrous
  195. 351W Swap time.
  196. fuel injector 2 carb
  197. Exhaust Note????
  198. K&N Filter Cleaning Tips?
  199. exploder heads/intake without egr and smog
  200. 5.0 to 4.6 swap
  201. Explorer swap with codes
  202. what 351 in 75 montego?
  203. Theoretical build
  204. swapping in a 155 GPH fuel pump in tomorrow...
  205. #3 spark plug chalky black... and misses
  206. Electric Water Pump?
  207. Quiet Performance Mufflers?
  208. The explorer gt40p header thread
  209. adjustable fuel regulator?
  210. performance Muffler flow and noise data
  211. Stock converter stall and general converter discussion
  212. Lightning 351 swap feasibility?
  213. fastest box?
  214. possibly stupid emissions/aftermarket heads question
  215. Theoretical Build: 5.0 in a Box
  216. Mystery Distributor/ help an idiot get durasparked
  217. rebuild kits?
  218. Solved my own mystery
  219. mustang oil pan in 302 colony park '85?
  220. headers on 302 panther
  221. HO/explorer swap questions, +rebuild kits?
  222. BBF 460 in a Box?
  223. update on 5 speed/306 swap! pics of trans!
  224. 4.6L Mods
  225. Totally insane swap thought : 2.3 Turbo!!!!
  226. porting stock lower intake
  227. Stock 302, to rebuild or to swap?
  228. CFI. Help?
  229. roller rockers?
  230. CFI to CARB-Advantages, Disadvantages
  231. Installing Tach and Temp gauge...
  232. Electric Fuel Pump VS Mechanical
  233. HO vs gt40 intake @low rpm, any difference?
  234. what valve springs for GT40 or Ps
  235. 5.0 build
  236. port and polish: dremel and AlO grinding ball?
  237. Quietest performance mufflers
  238. gt40 gtp40 help me decide and run down the parts list for 87 GM
  239. 5.0 HO need some advice.
  240. 351w Cam
  241. what to do w/ the wagon ... OR ... my accidental project
  242. Questions regarding intakes & ecm upgrades for an 86 vic
  243. what was issue with throttle body spacer & egr with HO?
  244. Mass Air Swap, Quick ?'s
  245. hesitation/ miss issue 89 vic
  246. Mark VI "Edelbrock Performer" Carb & Intake Conversion.
  247. considering a new low budget combo for my car
  248. Here's the latest
  249. 4.6swap?anybod else done it in box
  250. HO conversion/differential questions
