Big Block Techie stuff
    OK Aluminum or Iron? Port and polish?
    Cast or Forged Pistons? Cast or moly rings?
    Do I need to replace the stock crank? rods?
    Intakes. Dual-quad? Single? Air-Gap style?
    Custom headers. Have to be. Fox types wont fit the box!
    Carb. Holley? Edelbrock? Demon? Predator?
    Future Mods (Year or more)
    256cid single carb blower, and possibly plate nitrous.
    Useage
    Weekend streetfighter, and bi monthly 1/4 runs. Some crusin' and show 'n' shines (ie burnouts!)
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
    Forge it all
    aluminum heads will help shave the weight the 460 is adding to the car
    stroke it
    single non-airgap works find and is cheaper
    get ahold of the guy on cvn with the 460 box, maybe his guy can make a copy of his a lil cheaper than you can get some done for
    Holley will work for the amount of street driving you wanna do, but wont be as easy to setup right
    '80 Town Coupé
      i got a nice 2bbl intake hehe
          2bbl is good!
            Useage
            Whoa, your all over the map here. Building an engine for naturaly asperated is different than blown applications. If I were doing this. I would start out with basicly a stock running engine put it in a car and start running / racing it. Get all the install issues and such worked out first. A Fox swap oil pan should work. Up grade intake and stuff from swap meets.
              Yeah, my old 2bbl...that friggin motor would scream. Would have loved to have it with an intake, cam, and headers.
                Useage
                HEads- Aluminum, FRPP Cobra Jets
                Forged pistons, moly rings
                Crank and rods should be fine if you're not spinning it too high
                Dual Quad intake, make sure it's got a streetable powerband though
                Holley cabs if you can manage to tune 2 of them, if not, Edlebrocks
                Nick
                88 Colony Park LS
