I've seen these on a couple of panthers and I was wondering if they work pretty good as replacements for the interior. I have a similar lighting setup to a town car, with lighted door panels, dome map lights, etc.
Led bulbs for the interior
Associated Panthers:
http://www.cardomain.com/ride/2128327Tags: None
I know for sure the colored ones make great mood lighting. Wether or not you can read a map with the white ones it to be determinedPete ::::>>> resident LED addict and CFI defector LED bulb replacements
you bet your azz they do!!! good ones too. cant promise you can read a map to them though... check it -
http://www.grandmarq.net/vb/showthread.php?t=5923Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Those were the sweet leds I was looking for thanks!
I saw that you replaced the bulbs in the speedo with leds, was it hard to do?
The panther speedo looks alot better with leds in it vs. the standard green lighting, might have to ditch my speedo bulbs also.Current rides - 1991 Ford Thunderbird 3.8 v6 (gas saver/DD) - New Heads/Headgaskets with ARP studs, Air Silencer Delete, 70mm MAF, Plasti-dipped Matte Black with a Silver Metalflake Overlay, Muffler Delete, some LED's, 30.233 MPG for high MPG average!
not too hard, the top two came out just by removing the face, if you have the bottom two you might have to remove the whole cluster.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
its worth it!!!!! these blue bulbs are only maybe a buck more each. White ones cost more too.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
actually some of the dome lights do use a wedge base bulb... Ive seen both - some with the glass fuse looking bulbs, some with wedge base.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
