so what would it take to change a (EDIT: 86 ford LTD, sorry for the typo) 87 ford LTD -3 speed automatic to a 90 CV -4 speed automatic?
3 speed auto to 4 ...
there is no 3 speed in the 1987 boxes.............townys have had 4 speed auto's since 1980, not sure when vics, gm's got em prob no later than 1983........if you only have 3 speeds, there is a problem
AOD should bolt right in then. Might have to work out the TV cable, but probably a TV setup from a Tbird or whatever should fit right up. Actually, since many fox body cars had AODs in those years, I imagine you could steal most any part of the linkage or crossmember you might need to put it together.86 Lincoln Town Car (Galactica).
Originally posted by gadget73AOD should bolt right in then. Might have to work out the TV cable, but probably a TV setup from a Tbird or whatever should fit right up. Actually, since many fox body cars had AODs in those years, I imagine you could steal most any part of the linkage or crossmember you might need to put it together.
- well the only thing i am worried is about if the speedo will be correct after the switch
- what would a decent price be from a tranny shop switching out the tranny's?
or reasonable price? lol
yea rob the aod and parts required from a cougar or thunderbird up to 87
Just find out what rear your LTD has and get the correct speedo gear for the AOD to match it up.
Price for an average shop to do this kind of swap is anyone's guess. I'd say $expensive. Its not a major chore if you've got the tools and ability to swap a trans yourself.86 Lincoln Town Car (Galactica).
ok sorry i have been gone for so long ...
well i have a tranny ... so i am looking for the parts to change to the 4 speed
i have to have the car done in around 3 1/2 months ...
so if there is anyone that has the parts or can get them for me i sure could use the help, thanks
