Drilled holes in doors
    Hey, I just took my car to the shop to get my two window motors replaced and when I got it back I noticed they drilled three holes in each door frame(bottom/ middle of door). I can see a bolt under each hole. Is it normal for them to drill holes to gain access to the these three bolts? The car is 1986 Grand Marquis Coupe. Thanks
    1986 Grand Marquis LS coupe [/url] http://photos.yahoo.com/leo76830
    1986 Grand Marquis LS 2 Door
    This is normal. There is no access holes in the doors. To remove the motor bolts, you have to drill the holes.
      its what I had to do as well....
      btw NICE MERC!!!! I love that light blue color.
        Okay, that makes me feel a lot better, I thought they were just being lazy. I picked up some Por15 to coat the bare metal where they drilled and will just pop some standard body plugs in to seal it off. All but one are completely covered by the trim panels. Thanks for the info and compliments.
          It was obviously too much for Fords door cutters to make 3 small holes in the door while they were making the other holes.
          At least you don't have to guess where to drill. The doors have dimples in the three spots where drilling is required. Just drill your hole, make sure it's big enough to fit an 8mm socket on an extension through and you're good to go.
          Save a seal, club a liberal.
            You can change em without drilling but its a PITA.
              Yeah no kidding. It sucks!
