I was messing with the cars tonight and noticed that the '91 GM vacuum canister was a plastic box rather than the tin can like the '88/'89's have. The plastic box looks a lot cleaner under the hood than a black soup can, so I thought I would just run to the yard tomorrow and grab a couple plastic ones. Problem I noticed is the length of the vac line. It is too short to reach the connector on the plastic box. Other than that, it seemed pretty clean cut. Any benefits to either one (plastic box or tin can) other than looks?
vacuum canisters
Plastic won't rust out, obviously - I replaced Angie's soup can with the plastic box off a '91 TC, looks a whole lot cleaner. Dunno how your vacuum lines go, but I managed to get the new thing right in the stock location, and the vacuum line fit just fine - here's a pic:
you can make that vacuum line go any which way you want! but loose, of course.
You might need some vacuum line adaptors if the hoses are different sizes - I bought an assortment pack of themPete ::::>>> resident LED addict and CFI defector LED bulb replacements
