Question for the Mercury folks
    Are any of you running LED bulbs in your speedometer? If so, how do they look?
    Save a seal, club a liberal.
    If they do, Im sure they look great
    Thinking about the new merc???? Im sure they would work fine.
      Matter of fact, I'm thinking of replacing all the interior bulbs with blue leds.
        nice!!!!
        i think some places the older style inverted LED bulbs might work better than the new style ones, like the ash tray and glove box. Also cig lighter housings, key locks, any where the bulb isnt in direct view or doesnt point strait out of the lamp assembly
        Those are like a buck apiece now too, lol
          I ordered some for my speedo about a week ago, the same ones that pete suggested. I'l get a pic up when i get them in, it should look great!
            Dammit, I think a trend has started here. I just got my blue leds from hong kong the other day, I only installed them in the doors since I have to wait until the weekend to replace the speedo bulbs. What about the courtesy bulbs in the lower dash though, they don't look like leds would work with them. They use old style bulbs with a seperate contact plate connected to plug. The dome light uses a strange bulb or led also.
            Associated Panthers:
              Just installed the blue 194 led's in the dash today, the same ones that blaze and 85crownhpp have in the dash. Its harder to do on merc clusters vs. vics plus you need 5 to 6 blue(or what color you use) 194 led bulbs.
              First, to get to the merc cluster, you need to remove the dash pad and unplug the battery. Then remove the trim around the cluster, you can leave everything else on there. To get the headlight switch out, pull it all the way out and turn it both ways until it disconnects, might take a minute or two. Then there are 4 torque screws you need to remove that hold the cluster in place, one on each corner of it. After its unscrewed, turn the ignition key on to the on position, drop the gear level down to 1st gear, and make sure the parking brake is on plus block the wheels. This will allow you to pull the cluster out to have access to all the bulbs, otherwise you will not be able to get your hand in there for the ones you need.
              I left the idiot lights alone along with the parking brake bulb, so 7 of the bulbs on the dash display do not need led replacements unless you want to buy more bulbs. I replaced my turn signals with leds, which look cool during the daytime. So, it leaves you with 3 bulbs on the right, two on the left of the cluster plus the one bulb at the top for the gear indicator, which is the easiest to get to first. I found the easiest way to do it was to replace all the bulbs by reaching from the left side of the cluster, except for the two on the corner of the right side of the cluster.
              The end result was awesome, but I need a better camera. It makes it look like the cluster is really bright on some areas and I couldn't get a still picture even when I wasn't moving. I think the leds reflected into the lens or something else or I don't have a good setting for that type of picture. The cluster looks just like anyone who has replaced their stock bulbs with leds, I can guarantee that and I was definitely not disappointed.
                I LIKE THAT!!!
                Thanks for the pics mang!
                  Damn those are bright!
                  I'm gonna put blue LED's in GL's dash, someday lol
                    Wow...
                    '95 Ford Bronco XL -
                    sigpic :rebel:
                      That was always my concern about going to LED, that I wouldn't be able to see the dash properly. OK, now I have no excuse, other than I need to pick a color.
                        That looks great, but you would be fine just replacing the five bulbs for illumination right?
                          I just edited the post above, I forgot to mention I replaced the turn signals bulbs with leds. I was worn out from a long day of work and I put the smog pump (wanted to let the engine cool) back on at the same time when I changed the bulbs, wasn't even paying enough attention to what I was doing. I put in as many bulbs as I thought I would need because I was afraid it wasn't going to work, I seen it happen when I tried to do the same thing with my dad's camaro. I also didn't realize that I replaced the turn signal bulbs either but it looks cool in the daytime.
                          That would make for three on the speedo side of the cluster, one for the gear indicator, and I think 2 to 3 on the left side of the cluster though. You would be fine if you ordered 6 bulbs, they are usually sold in pairs. There might be only 2 on the left side of the cluster that control illumination, one right below the brake light and then one right where the gas gauge is. I thought might have been 3 on the left side, but I only really replaced every top corner light that I could get on both sides.
                            hell yes!!!!! Spread the LED fever!!!!!!!!!!
                              Ya, i just double checked and there are 5 total. 3 on speedo side and 2 on the gas guage side. the one above the gear selector is only for the high beam light, but since it is blue anyways it would work out just fine.
