View Full Version : the tranny in
marquisman
01-02-2005, 09:56 PM
my dads 88 colony park wit overdrive trans has lost 3rd gear! it happened on the hiway when the car was in overdrive(was struggling in OD) and it suddenly lost power, i pulled off to the side of the road, put it into park and back to drive(D) and it would only shift to 2nd gear. is the tranny shot? or somthin in the valve body?
grandpaslincoln
01-03-2005, 12:02 AM
My LTC did that once. It shifted from first to second, and then the engine just kept winding up and up, wouldn't shift to 3rd. So I put it in OD, then put it back down into drive, it shifted to 3rd gear, never had another problem with it.
Did it feel like the transmission was slipping at all? I don't have any definate answers for you, my experience with AOD's is limited. Someone will chime in. good luck man.
Grand Marquis GT
01-03-2005, 07:42 AM
Sounds like a TV linkage problem. Check to see if it is connected to the throttle lever, or if it is binding down by the transmission.
DO NOT DRIVE IT AGAIN UNTIL THIS IS FIXED!!!
Let us know what you figure out.
marquisman
01-03-2005, 02:10 PM
i feel stupid asking this because i probably know what it is but, whats the TV linkage?is it the cable from the throttle to the tranny because, that is all good and hooked up!
Paul_
01-03-2005, 02:21 PM
it may look hooked up but the factory used a plastic or a rubber grommet and over time these deteriorate. theres a brass one available. let me try to dig up a part #. stu was cool and sent me a set of tranny seals, a filter w/gasket and the brass grommet and the cotter pin.
Paul_
01-03-2005, 02:47 PM
heres the part #:
F3SZ-7H303-B
marquisman
01-03-2005, 04:19 PM
hey, thnx alot!
hdlogistics
01-04-2005, 10:38 AM
Since my '91 GM has the original plastic grommet, I better hit the parts store & buy the brass replacement soon. You guy's are right about the small cost turning into a huge rebuild.
Paul_
01-04-2005, 11:01 AM
i've had about 6 aods fail me since i've had my license. i'm sure i coulda saved 5 if i had known then what i know now.
hdlogistics
01-05-2005, 08:23 PM
I had to visit a few Ford dealers to get the part but it only cost $2.06CAD. Seems the brass bushing is in short supply in my area.
marquisman
03-10-2005, 08:09 PM
i forgot to ask if this bushing is on the tranny or on the cable linkage that conects to the throttle? i feel so stupid asking this! :coocoo:
trwp72
03-10-2005, 10:16 PM
The linkage is where it connects to the throttle body... look directly under where the large butterfly is, and you will see it between the throttle linkage and the plenum.... I used to have a picture somewhere.. let me see if I can find it...
http://i2.photobucket.com/albums/y20/trwp39/engine2.jpg
AH, here it is!!!
Also, be REAL careful putting the little pin back in... it is REALLY easy to drop it, or launch it somwhere...
Tom...
marquisman
03-11-2005, 07:16 AM
i knew that, lol...thnx alot(i know alot about EFI but im a carb man!)
Lincolnmania
03-11-2005, 12:49 PM
sounds to me like the tv cable came unhooked
marquisman
03-11-2005, 03:29 PM
exactly, lol, but now i got it back together and still does the same shit and there is a bit of play.
