I'm looking into a new set of Chrom 18" wheels wiht 245/45/18 tires, and am wondering if they would fit on my car without and problems. i.e. rubbing problems, turning problems, or anything else like that.
Will 18" wheels fit on my 1994 Grand Marquis?
what are the specs of the wheel? I'm talking width, bolt pattern, and backspacing. You want to more than 8" wide (for the front at least, rear can go up to 10" if you want), 5x4.5 bolt pattern, and zero offset. Now I highly doubt you'll find an 18" wheel with zero offset, so you may need to use some spacers there - they run abou $60 a pair on ebay, and you'll want to put some new studs in them, just to be on the safe side. Post a link to the wheels you're considering and we can tell you more.
