Brake fluid
    Brake fluid
    The brake fluid in my Merc hasnt been changed in about 6 years. What would the procedure be to drain the fluid and refill it? Open all the bleeder screws and pump it out, then re-bleed the system? Sounds about right, I'm just double checking in case there's something I don't know.
    Nick
    88 Colony Park LS
    use a turkey baster or other device to suction out the master cyliner - also us that to 'squirt' fluid arond and try to free up some gunk at the bottom of the resivoir to suck it out.
    Then bleed - it will take less time that way
      You can bleed it the lazy way after changing the fluid in the reservoir by just opening the bleeder screws till the fluid runs out clear. Keep topping up the fluid in the reservoir and it should be fine. No need to pump the pedal really.
        Arite, thanks guys. I heard from someone else today that I could open all the bleeder screws, pump all the fluid out, then blow compressed air through the system in order to blow out any gunk, and then refill it.
        Nick
        88 Colony Park LS
          all the shops i have worked at just keep the reservoir filled and have a pneumatic vacuum hookeed up to one bleeder at a time. they use the vacuum at each bleeder till it is clear and then move on to the next. you should go in this order to avoid air pockets.
          passenger rear
          drivers rear
          passenger front
          drivers front
          you could use a air line to blow it all out but then you have a chance of sending the clog and crap in the lines further down and it could end up anywhere. it could clog one line, and just flush out the rest. unless you open one bleeder at a time to only allow the pressure to exit the one instead of flushing them all at once.
          Addicted to 86-87 Panthers
