Anyone read this?
oh yes. AFR makes a bad-ass head. got $$$$???Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
but still
500 tops for a ho motor out of a 91-92 stang
1299 for the heads-assuming they're sold in pairs would be more if they are not
300-400 for the roller rockers
headers
and you're still looking at a bargain. save your pennies, use ebay, and for maybe less you gots yourself one mean 302Save a seal, club a liberal.
AFR 165CC heads.......................$1,325.00
Comp. Cam 1.7:1 rockers...........$378.99
ARP headbolt kit.........................$37.99
Fel-Pro Head gaskets (2).............$61.98
Fel-Pro Intake gaskets................$19.99
Weiand Intake manifold..............$165.99
Road Demon Jr. Carb.................$259.95
Doug's Tri-Y headers..................$549.95*
Total.........................................$2,7 99.84
*Chromed headers- $389.95
hmmm
I'm still considering the AFR heads on my HO. I'll have about $3000 to put into the engine once I pull it from the Mark.
SuperFord Profile
Support safe sigs
-sigs should not exceed 600 pixels wide
-sigs should not consist of more that 25 lines (including pics) when viewed at 800x600
-Multiple images exceeding 600 pixels wide should have a space between them to allow for wrapping
-Total sig size should not exceed 60k
Remember, only you can prevent sig abuse....
it was/is a great article. just goes to show how well the stock HO cam really works for most applications.
with that being said, there are a couple things you need to consider
1) they used a carb and an aftermarket intake. I doubt it would have made similar HP with a stock or near stock SD EFI system.
2) they used headers that will not fit in any late model chassis, Panther or Mustang/FOX
3) with the stock cam, high flowing heads moved the peak HP and torgue very high up in the RPM range (405 HP at 6200 rpm and 380 torque at 4300 rpm). you would need a serious converter and at least a 4.10 gear to get almost any street car moving.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
