17 x 8 cobra rims
    17 x 8 cobra rims
    Does anyone know if 17 x 8 cobra rims will fit a 92 grand marquis?
    \"There\'s no replacement for displacement\"
    1992 Mercury Grand Marquis
    4.6 liter v8--only option
    Electric fan, Bosche Platinum Plugs, MSD Coil Packs,
    Cold air induction(cone filter) and Single 3-inch exhaust cat-back system with DynoMax muffler.
    Yep.
    You will need spacers (1/4" to 5/16") on the front. That will require longer front wheel studs. MOROSO makes 3" wheel studs that will fit, but you'll have to open up the hub hole slightly. (I'll have to check on the part numbers that I used and the drill size I bought)
    It's a bit of work, but the results in looks and handling are well worth it!
    Ray
    Car: 2004 Mercury Marauder
    Engine/Tranny: 49k miles and bone stock....for now
      yes they will fit with spacers...........on the box panthers they will fit too if you use 1" spacers on the front
      scott
