View Full Version : Tire Pressure
91 LTD
07-28-2006, 10:28 PM
anyone equalize( w/ one of those coiled hose things) their tire pressure?
mrltd
07-28-2006, 11:20 PM
I haven't
91 LTD
07-29-2006, 04:02 PM
Seems like its pretty important to racer types. Considering how important tire pressure is to mpg Im gonna do it once my car is running again. Who knows could affect alot of things, handling, tire wear, etc.
Southern_Pride
07-29-2006, 04:24 PM
I set all 4 of mine at 30lbs. Only cause I do a lot of highway driving.
91 LTD
07-29-2006, 05:16 PM
What's it say to pump em to? Cause if its 35 Id fill em back up, FAST. Here's why: www.tirerack.com/tires/tiretech/techpage.jsp?techid=1
I roll +5 psi all around.
Lincolnmania
07-29-2006, 07:21 PM
i set allmine to the max pressure on the sidewall.........running 44lbs in the lss
91 LTD
07-29-2006, 07:35 PM
WORD.
mrltd
07-29-2006, 10:14 PM
Most racers I've seen use a pyrometer and a pressure gauge to set pressures.
An inexpensive way to get in the ballpark for the correct tire pressure (if you don't bother with the manufacturers recomendation) is to put a chalk mark across the tread and drive it a few feet and see where the chalk is worn off. Outer edges worn off, need more pressure. Center of the tread worn off, too much pressure.
Or just pay attenttion to how the tire is wearing and adjust accordingly.
I've never run a tire at the max pressure. Always works better for me closers to the manufacturers recommendation.
