inertia cutout in 94 marquis
    Where is the inertia cutout in a 94 marquis
    If you mean the inertia switch it is located in the trunk, on the driver's side above the rear wheel. Behind the "rug"-type stuff, it's velcro'd in. There should be a box with a red button on top. If you are supposed to disconnect it to depressurize the fuel system, I always just disconnect the harness from the switch itself.
    Apparently it is to shut off the fuel flow in case of an accident, hence the name "inertia". Like the locking seat belts, it senses the inertia of the vehicle and makes a change(although at a much higher level of inertia obviously), being shutting of the fuel pump so that raw fuel is not pumping out at the scene of an accident to avoid fire.
    And gracious salutations and visions of peace to you and your loved ones...ROTFLMAO!
    My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
      I blew a LR tire once and it set off the damn switch, took me 10 minutes to remember it was there......I was thinking WTF it wont start!
