Pinion Shaft
    Pinion Shaft
    Anyone know offhand how many splines an early aero pinion shaft might have?
    I really don't feel like removing all that stuff if I don't have to...
    Maybe someone who has one off the car *cough* BMFer *cough* or who is around them daily could just count 'em up next time you run into one.
    Thanks.
    -mercenvy
    My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
    Most are 28 but the only way to be shure is to pull and count.
      Thanks for your response. I have one out but it's not for a Panther...it's actually a Mustang pinion. Since it is an 8.8 I figured it would be the same but didn't want to assume that.
      Thanks for your time.
        Sorry I was thinking axle shaft not a pinion shaft. Not shure on the pinion just have had 9" stuff that far appart. I think most of the pinions are the same just axle splines differnt.
          Yeah I'm just hoping that the pinion shaft I have will work with the companion flange I plan on using.
          Thanks for your response!
            You must have gotten a PI aluminum drive shaft with the big expensive u-joints?
              all the 8.8" pinion gears shafts/splines are the same to my knowledge. Since people regularly harvest 3.55/3.73 gears from explorers and such and swap them over, I would guess they work fine.
                Yup they're all the same AFAIK too. If you're talking axle splines, that's a little different. There are 28 spline (most panthers) and 31 spline variations.
                :worship: Aeros r00l.
                  Thanks guys for your responses. I ASSumed that they were the same but you know how that goes...
                  I have the 28 spline axles, and a 28-spline T/L diff with 3.73s...so I'm all set there. Just wanted to know if the pinion would work. And no, I don't have expensive anything....lol...just that I will need to have a custom driveshaft made and wanted to know.
                  Thanks for the info
                  -mercenvy
