PDA
View Full Version : Just need a little advice/troubleshooting on horn/relays !
1988VIC
08-14-2006, 12:57 PM
Alright check this out guys....(1988 Crown VIC) I just bought new horns after checking all the wiring out. Wiring is A-OK. The hardware is definitely what is causing the fuse to blow. So I disconnected the horns ( which are single terminal ) and plugged up the new horns. Horns wouldnt work off of one terminal being plugged by OEM horn plug. So I took the remaining terminal and plugged to chassis ground and the fuse is now basically the trigger. When fuse is in, the horns blow hard. And when I unplug the fuse, the horns stop sounding. But the fuse does not blow at all anymore. Should I plug the remaining terminal to somewhere besides the ground? I'm contemplating using a relay, in some form, to bypass as much of the stock wiring as possible. Does anybody have any light to shed on this predicament? I'm willing to try anything at this point, so please share if you have any ideas.
Thank you.
gadget73
08-14-2006, 09:05 PM
I think you need 2 horns. Not super sure of the wiring, but if memory serves, there are 2 + wires for the horns. Its also possible that the relay is just stuck. The relay should be on the driver's side, just behind the wash bottle on the bracket with the other relays. Its the small one at the bottom that you need.
85crownHPP
08-14-2006, 09:56 PM
my horns are 1-wire chassis ground. Id bet you need power and ground for those horns. do they both have 2 terminals or just one?
Ive installed a few aftermarket horns with 2, they usually included a black wire with terminal and ring ends to make the chassis ground.
