View Full Version : ok, stupid question
seneeb
08-21-2006, 09:20 PM
at scottfest I bought an electric fan because i was looking at my car (the 97), saw the clutch fan, and just assumed that was it.
well, tonite i was looking at it closer, and that's not the case. My car has both a clutch fan and an electric fan.
why?
the only thing I can think of as to why is for when the a/c is on.
DanHool
08-21-2006, 10:06 PM
my 94 caprice had both.... and the bitch still overheated. i would assume you could get a newer, better electric fan and be better off, but you might wanna hang onto the old fan just in case you need to go back to that setup
93 Marquis
08-22-2006, 07:07 AM
The electric fan comes on when the A/C is on or when the engine temp climbs over 220*. Ford started using it in '96 when they found out that R134a doesn't work as well as R12 at low speed. The auxillary fan increases air flow through the condensor to make up for it.
Ray
seneeb
08-22-2006, 07:29 AM
ok, that's what I figured it was for, just wanted to verify :)
I can run a beefier efan and do away with the clutch fan then :)
93 Marquis
08-22-2006, 08:36 AM
I'm running a '96 auxillary fan as my only cooling fan. It's run by a stand alone controller and works great.
p71towny
08-22-2006, 10:49 AM
Yeah, I just have my electric fan as well. Use the electric fan for the 84.
merc6
08-22-2006, 11:59 AM
were you going to use the fans as puller or pusher?
And yes ford and mzda are notorious for that. At leas in the newer cars they pull timming when the car heats up before turning on the e fans. IIRC mazda 6 pulled timming at like 210 and somewhere around 220 is when the fans innitialy kicked on. On the mercury using water wetter and Xcal2, I was able to combat that.
seneeb
08-22-2006, 05:50 PM
well, i took off the clutch fan. It didnt get too hot. was a little hotter than with the clutch fan on.
I think I'm going to get a controller like 93 marquis has though to get it to turn on at a lower temp.
gabegt90
08-22-2006, 08:54 PM
98 was the first year they got rid of the clutch fan
DanHool
08-22-2006, 10:08 PM
you need a dimmer switch
seneeb
08-23-2006, 09:53 AM
expound please sir!
dimmer switch for what? :)
DanHool
08-23-2006, 10:52 AM
for your fan! that suggestion yesterday came from pure drunkenness, but it seemed brilliant at the time
http://static.howstuffworks.com/gif/dimmer-switch-intro.jpg
