I had a problem about 1 week ago with my headlights they wouldnt come on but the parking light was on and flickering and you could hear a relay in the car opening and closing the relay I found that it was right behind the heater and air controls. I checked all wiring and everything was good. Once it set for a while about 30 min the headlights came back on no problmes all weekend long at Scottfest and all week long here until today.
Out of no where same problem happen all over again but worse. The parking light came on and would no go out i had to pull fuse #4 which is a 15 amp to shut the parking light and dash cluster off. I checked across the empty slot with the fuse out and im reading 12vdc i know that should not be there..I also replaced the headlight switch but that didnt help same problem. Also one thing before all this happen 1 week ago i was about to get my car washed at the drive thru wash and i turned my car off to do something when i went to turn it on teh pull up about to get it washed teh car wouldnt start like it did that day at the track before we were about to leave. The attendant at the car wash said he saw smoke come from my starter solenoid......Thats all the info i got for now any question ask me and i will try to explain...Would a fuselink do this? But i know a fuselink once broke kills the power thou..Also when i go to hit the highbeam switch a yellow 20 amp fuse blows it did it last week just like this once the circuit or load is clear it does not blow...And yes all this did happen before Scottfest just this time it seems worse....I dont think its the multi function switch either ...
