Early Aero CEL Codes
    DIAGNOSTIC TROUBLE ³ DEFINITIONS ³
    ³ CODES ³ ³
    ³ 111 ³ System Pass ³
    ³ 112 ³ Intake Air Temp (IAT) sensor circuit below minimum voltage/ 254øF ³
    ³ ³ indicated ³
    ³ 113 ³ Intake Air Temp (IAT) sensor circuit above maximum voltage/ -40øF ³
    ³ ³ indicated ³
    ³ 114 ³ Intake Air Temp (IAT) higher or lower than expected ³
    ³ 116 ³ Engine Coolant Temp (ECT) higher or lower than expected ³
    ³ 117 ³ Engine Coolant Temp (ECT) sensor circuit below minimum voltage/ 254øF ³
    ³ ³ indicated ³
    ³ 118 ³ Engine Coolant Temp (ECT) sensor circuit above maximum voltage/ -40øF ³
    ³ ³ indicated ³
    ³ 121 ³ Closed throttle voltage higher or lower than expected ³
    ³ 121 ³ Indicates throttle position voltage inconsistent with the MAF sensor ³
    ³ 122 ³ Throttle Position (TP) sensor circuit below minimum voltage ³
    ³ 123 ³ Throttle Position (TP) sensor circuit above maximum voltage ³
    ³ 124 ³ Throttle Position (TP) sensor voltage higher than expected ³
    ³ 125 ³ Throttle Position (TP) sensor voltage lower than expected ³
    ³ 126 ³ MAP/BARO sensor higher or lower than expected ³
    ³ 128 ³ MAP sensor vacuum hose damaged/disconnected ³
    ³ 129 ³ Insufficient MAP/Mass Air Flow (MAF) change during dynamic response ³
    ³ ³ test KOER ³
    ³ 136 ³ Lack of Heated Oxygen Sensor (HO2S-2) switch during KOER, indicates ³
    ³ ³ lean (Bank #2) ³
    ³ 137 ³ Lack of Heated Oxygen Sensor (HO2S-2) switch during KOER, indicates ³
    ³ ³ rich (Bank #2) ³
    ³ 138 ³ Cold Start Injector (CSI) flow insufficient KOER ³
    ³ 139 ³ No Heated Oxygen Sensor (HO2S-2) switches detected (Bank #2) ³
    ³ 144 ³ No Heated Oxygen Sensor (HO2S-1) switches detected (Bank #1) ³
    ³ 157 ³ Mass Air Flow (MAF) sensor circuit below minimum voltage ³
    ³ 158 ³ Mass Air Flow (MAF) sensor circuit above maximum voltage ³
    ³ 159 ³ Mass Air Flow (MAF) higher or lower than expected ³
    ³ 167 ³ Insufficient throttle position change during dynamic response test ³
    ³ ³ KOER ³
    ³ 171 ³ Fuel system at adaptive limits, Heated Oxygen Sensor (HO2S-1) unable ³
    ³ ³ to switch (Bank #1) ³
    ³ 172 ³ Lack of Heated Oxygen Sensor (HO2S-1) switches, indicates lean (Bank ³
    ³ ³ #1) ³
    ³ 173 ³ Lack of Heated Oxygen Sensor (HO2S-1) switches, indicates rich (Bank ³
    ³ ³ #1) ³
    ³ 175 ³ Fuel system at adaptive limits, Heated Oxygen Sensor (HO2S-2) unable ³
    ³ ³ to switch (Bank #2) ³
    ³ 176 ³ Lack of Heated Oxygen Sensor (HO2S-2) switches, indicates lean (Bank ³
    ³ ³ #2) ³
    ³ 177 ³ Lack of Heated Oxygen Sensor (HO2S-2) switches, indicates rich (Bank ³
    ³ ³ #2) ³
    ³ 179 ³ Fuel system at lean adaptive limit at part throttle, system rich ³
    ³ ³ (Bank #1) ³
    ³ 181 ³ Fuel system at rich adaptive limit at part throttle, system lean ³
    ³ ³ (Bank #1) ³
    ³ 184 ³ Mass Air Flow (MAF) higher than expected ³
    ³ 185 ³ Mass Air Flow (MAF) lower than expected ³
    ³ 186 ³ Injector pulsewidth higher than expected (with BARO sensor) ³
    ³ 186 ³ Injector pulsewidth higher or MAF lower than expected (without BARO ³
    ³ ³ sensor) ³
    ³ 187 ³ Injector pulsewidth lower than expected (with BARO sensor) ³
    ³ 187 ³ Injector pulsewidth lower or MAF higher than expected (without BARO ³
    ³ ³ sensor) ³
    ³ 188 ³ Fuel system at lean adaptive limit at part throttle, system rich ³
    ³ ³ (Bank #2) ³
    ³ 189 ³ Fuel system at rich adaptive limit at part throttle, system lean ³
    ³ ³ (Bank #2) ³
    ³ 193 ³ Flexible Fuel (FF) sensor circuit failure ³
    ³ 211 ³ Profile Ignition Pickup (PIP) circuit failure ³
    ³ 212 ³ Loss of Ignition Diagnostic Monitor (IDM) input to PCM/SPOUT circuit ³
    ³ ³ grounded ³
    ³ 213 ³ SPOUT circuit open ³
    ³ 214 ³ Cylinder Identification (CID) circuit failure ³
    ³ 215 ³ PCM detected coil 1 primary circuit failure (EI) ³
    ³ 216 ³ PCM detected coil 2 primary circuit failure (EI) ³
    ³ 217 ³ PCM detected coil 3 primary circuit failure (EI) ³
    ³ 218 ³ Loss of Ignition Diagnostic Monitor (IDM) signal-left side (dual plug ³
    ³ ³ EI) ³
    ³ 219 ³ Spark timing defaulted to 10 degrees-SPOUT circuit open (EI) ³
    ³ 221 ³ Spark timing error (EI) ³
    ³ 222 ³ Loss of Ignition Diagnostic Monitor (IDM) signal-right side (dual ³
    ³ ³ plug EI) ³
    ³ 223 ³ Loss of Dual Plug Inhibit (DPI) control (dual plug EI) ³
    ³ 224 ³ PCM detected coil 1, 2, 3 or 4 primary circuit failure (dual plug EI) ³
    ³ 225 ³ Knock not sensed during dynamic response test KOER ³
    ³ 226 ³ Ignition Diagnostic Module (IDM) signal not received (EI) ³
    ³ 232 ³ PCM detected coil 1, 2, 3 or 4 primary circuit failure (EI) ³
    ³ 238 ³ PCM detected coil 4 primary circuit failure (EI) ³
    ³ 241 ³ ICM to PCM IDM pulsewidth transmission error (EI) ³
    ³ 244 ³ CID circuit fault present when cylinder balance test requested ³
    ³ 311 ³ AIR system inoperative during KOER (Bank #1 w/dual HO2S) ³
    ³ 312 ³ AIR misdirected during KOER ³
    ³ 313 ³ AIR not bypassed during KOER ³
    ³ 314 ³ AIR system inoperative during KOER (Bank #2 w/dual HO2S) ³
    ³ 326 ³ EGR (PFE/DPFE) circuit voltage lower than expected ³
    ³ 327 ³ EGR (EVP/PFE/DPFE) circuit below minimum voltage ³
    ³ 328 ³ EGR (EVP) closed valve voltage lower than expected ³
    ³ 332 ³ Insufficient EGR flow detected (EVP/PFE/DPFE) ³
    ³ 334 ³ EGR (EVP) closed valve voltage higher than expected ³
    ³ 335 ³ EGR (PFE/DPFE) sensor voltage higher or lower than expected during ³
    ³ ³ KOEO ³
    ³ 336 ³ Exhaust pressure high/EGR (PFE/DPFE) circuit voltage higher than ³
    ³ ³ expected ³
    ³ 337 ³ EGR (EVP/PFE/DPFE) circuit above maximum voltage ³
    ³ 338 ³ Engine Coolant Temperature (ECT) lower than expected (thermostat ³
    ³ ³ test) ³
    ³ 339 ³ Engine Coolant Temperature (ECT) higher than expected (thermostat ³
    ³ ³ test) ³
    ³ 341 ³ Octane adjust service pin open ³
    ³ 411 ³ Cannot control RPM during KOER low RPM check ³
    ³ 412 ³ Cannot control RPM during KOER high RPM check ³
    ³ 415 ³ Idle Air Control (IAC) system at maximum adaptive lower limit ³
    ³ 416 ³ Idle Air Control (IAC) system at upper adaptive learning limit ³
    ³ 452 ³ Insufficient input from Vehicle Speed Sensor (VSS) to PCM ³
    ³ 453 ³ Servo leaking down (KOER IVSC test) ³
    ³ 454 ³ Servo leaking up (KOER IVSC test) ³
    ³ 455 ³ Insufficient RPM increase (KOER IVSC test) ³
    ³ 456 ³ Insufficient RPM decrease (KOER IVSC test) ³
    ³ 457 ³ Speed control command switch(s) circuit not functioning (KOEO IVSC ³
    ³ ³ test) ³
    ³ 458 ³ Speed control command switch(s) stuck/circuit grounded (KOEO IVSC ³
    ³ ³ test) ³
    ³ 459 ³ Speed control ground circuit open (KOEO IVSC test) ³
    ³ 511 ³ PCM Read Only Memory (ROM) test failure KOEO ³
    ³ 512 ³ PCM Keep Alive Memory (KAM) test failure ³
    ³ 513 ³ PCM internal voltage failure (KOEO) ³
    ³ 519 ³ Power Steering Pressure (PSP) switch circuit open KOEO ³
    ³ 521 ³ Power Steering Pressure (PSP) switch circuit did not change states ³
    ³ ³ KOER ³
    ³ 522 ³ Vehicle not in PARK or NEUTRAL during KOEO/PNP switch circuit open ³
    ³ 524 ³ Low speed fuel pump circuit openÄbattery to PCM ³
    ³ 525 ³ Indicates vehicle in gear/A/C on ³
    ³ 527 ³ Park/Neutral Position (PNP) switch circuit openÄA/C on KOEO ³
    ³ 528 ³ Clutch Pedal Position (CPP) switch circuit failure ³
    ³ 529 ³ Data Communication Link (DCL) or PCM circuit failure ³
    ³ 532 ³ Cluster Control Assembly (CCA) circuit failure ³
    ³ 533 ³ Data Communication Link (DCL) or Electronic Instrument Cluster (EIC) ³
    ³ ³ circuit failure ³
    ³ 536 ³ Brake On/Off (BOO) circuit failure/not actuated during KOER ³
    ³ 538 ³ Insufficient RPM change during KOER dynamic response test ³
    ³ 538 ³ Invalid cylinder balance test due to throttle movement during test ³
    ³ ³ (SFI only) ³
    ³ 538 ³ Invalid cylinder balance test due to CID circuit failure ³
    ³ 539 ³ A/C on/Defrost on during Self-Test ³
    ³ 542 ³ Fuel pump secondary circuit failure ³
    ³ 543 ³ Fuel pump secondary circuit failure ³
    ³ 551 ³ Idle Air Control (IAC) circuit failure KOEO ³
    ³ 552 ³ Secondary Air Injection Bypass (AIRB) circuit failure KOEO ³
    ³ 553 ³ Secondary Air Injection Diverter (AIRD) circuit failure KOEO ³
    ³ 554 ³ Fuel Pressure Regulator Control (FPRC) circuit failure ³
    ³ 556 ³ Fuel pump relay primary circuit failure ³
    ³ 557 ³ Low speed fuel pump primary circuit failure ³
    ³ 558 ³ EGR Vacuum Regulator (EVR) circuit failure KOEO ³
    ³ 559 ³ Air Conditioning On (ACON) relay circuit failure KOEO ³
    ³ 563 ³ High Fan Control (HFC) circuit failure KOEO ³
    ³ 564 ³ Fan Control (FC) circuit failure KOEO ³
    ³ 565 ³ Canister Purge (CANP) circuit failure KOEO ³
    ³ 566 ³ 3-4 shift solenoid circuit failure KOEO (A4LD) ³
    ³ 567 ³ Speed Control Vent (SCVNT) circuit failure (KOEO IVSC test) ³
    ³ 568 ³ Speed Control Vacuum (SCVAC) circuit failure (KOEO IVSC test) ³
    ³ 569 ³ Auxiliary Canister Purge (CANP2) circuit failure KOEO ³
    ³ 578 ³ A/C pressure sensor circuit shorted (VCRM module) ³
    ³ 579 ³ Insufficient A/C pressure change (VCRM module) ³
    ³ 581 ³ Power to Fan circuit over current (VCRM module) ³
    ³ 582 ³ Fan circuit open (VCRM module) ³
    ³ 583 ³ Power to Fuel pump over current (VCRM module) ³
    ³ 584 ³ Power ground circuit open (Pin 1) (VCRM module) ³
    ³ 585 ³ Power to A/C clutch over current (VCRM module) ³
    ³ 586 ³ A/C clutch circuit open (VCRM module) ³
    ³ 587 ³ Variable Control Relay Module (VCRM) communication failure ³
    ³ 617 ³ 1-2 shift error ³
    ³ 618 ³ 2-3 shift error ³
    ³ 619 ³ 3-4 shift error ³
    ³ 621 ³ Shift Solenoid 1 (SS1) circuit failure KOEO ³
    ³ 622 ³ Shift Solenoid 2 (SS2) circuit failure KOEO ³
    ³ 624 ³ Electronic Pressure Control (EPC) circuit failure ³
    ³ 625 ³ Electronic Pressure Control (EPC) driver open in PCM ³
    ³ 626 ³ Coast Clutch Solenoid (CCS) circuit failure KOEO ³
    ³ 627 ³ Torque Converter Clutch (TCC) solenoid circuit failure ³
    ³ 628 ³ Excessive converter clutch slippage ³
    ³ 629 ³ Torque Converter Clutch (TCC) solenoid circuit failure ³
    ³ 631 ³ Transmission Control Indicator Lamp (TCIL) circuit failure KOEO ³
    ³ 632 ³ Transmission Control Switch (TCS) circuit did not change states ³
    ³ ³ during KOER ³
    ³ 633 ³ 4x4L switch closed during KOEO ³
    ³ 634 ³ Manual Lever Position (MLP) voltage higher or lower than expected ³
    ³ 636 ³ Transmission Oil Temp (TOT) higher or lower than expected ³
    ³ 637 ³ Transmission Oil Temp (TOT) sensor circuit above maximum voltage/ ³
    ³ ³ -40øF (-40øC) indicated/circuit open ³
    ³ 638 ³ Transmission Oil Temp (TOT) sensor circuit below minimum voltage/ ³
    ³ ³ 290øF (143øC) indicated/circuit shorted ³
    ³ 639 ³ Insufficient input from Transmission Speed Sensor (TSS) ³
    ³ 641 ³ Shift Solenoid 3 (SS3) circuit failure ³
    ³ 643 ³ Torque Converter Clutch (TCC) circuit failure ³
    ³ 645 ³ Incorrect gear ratio obtained for first gear ³
    ³ 646 ³ Incorrect gear ratio obtained for second gear ³
    ³ 647 ³ Incorrect gear ratio obtained for third gear ³
    ³ 648 ³ Incorrect gear ratio obtained for fourth gear ³
    ³ 649 ³ Electronic Pressure Control (EPC) higher or lower than expected ³
    ³ 651 ³ Electronic Pressure Control (EPC) circuit failure ³
    ³ 652 ³ Torque Converter Clutch (TCC) solenoid circuit failure ³
    ³ 654 ³ Manual Lever Position (MLP) sensor not indicating PARK during KOEO ³
    ³ 656 ³ Torque Converter Clutch continuous slip error ³
    ³ 657 ³ Transmission over temperature condition occurred ³
    ³ 998 ³ Hard fault present ****FMEM MODE**** ³
    My car is a Shelby SVT Cobra GT Boss Grand Marquis Type R
    REPOST
    Sorry, I know that this is already stickied but I had to do SOMETHING.....
    Hasn't been any posts in who knows how long...
      Still, good info tho. Can you access this by jumping two terminals?
        Yes, Towny. There is a self-test harness which is attached to the driver's side fenderwell. I made a jumper wire to jump out the two terminals, one from the self-test harness and another from a smaller connector. Then I do the KOEO test and count the "blinks" of the CEL. I could use a scantool but I don't have one.
        I guess I could take a pic of it. Yeah, maybe I'll do that. That way people could check their own codes for free instead of going to Vato Zone, since most people who work there I wouldn't let near my car with a sponge, let alone a scantool.
          OBD-I is super easy to check codes yourself:
          Complete Code list and PCM self-test instructions
          -My Homepage, Panther info & FAQs-
          My Mint 96' Mercury Grand Marquis LSE -
          Modifications
          Click My Merc for more Pics!
            cool info
