94 marquis won't shift
    my car won't shift into gear .. i've checked the shift tube and its fine .. anything else to check ?
    linkages under the car? remove cover from steering column and make sure nothing has come loose and is inhibiting the shifter from moving. I think I recall someone mentioning a screw or something that worked loose but I don't remember it was a while ago on a different board.
    93 Town Car Cartier 150k mi
    01 CVPI, (Count Blackula)155k mi
      The shifter moves through the whole range, but the transmission doesn't engage?
      - or -
      Does the shifter come out of park?
      Ray
      Car: 2004 Mercury Marauder
      Engine/Tranny: 49k miles and bone stock....for now
        clicks in park on the colum but linkage dos'nt move on tranny ..
          I was just able to jack the car up on all 4 and get under it while running and maunualy shift it into gear .. took it off jacks while in gear and drove around and seemed to be fine just unable to shift from the colum
          I have a steep drive way has anyone heard of the cable breaking that goes from shift tube to trans ?
          Could this be a good reasson to fabricate a floor shifter ? humm ....
            I got under it for a better look this morning and the cable houseing has split apart not breaking the cable inside , but is'nt allowing it to work .. i'll post pics tommorw .. good ol ford product ...
              Yeah the cables can break. Hey its 12 years old, stuff happens. teamfordparts.com should be able to get you the replacement, and so can the local dealership if yours isn't staffed by idiots.
                yea i replaced a split cable on a ford truck recently
                try teamfordparts.com for the cable mang
                  The cables in our work trucks were notorious for that shit.
                  2005 Legacy GT *13.5 @ 96MPH*
                  2003 Mercury Marauder *Totaled*
