Hard Shifting 92 M75
    My AOD tranny is taking a dump I think...When im crusing at 30mph with very slight pressure on the pedal the rpms rise then it clunks into gear....It doesnt do this all the time but it does bug me.....And theres times where when I get on it where it doesnt want to shift and It runs like a dog....Hopefuly its just a missajusted linkage and nothing more
    R.I.P Linsey Nelson
    Originally posted by MeanVic84
    Chocolate Rain. Some stay dry and others feel the pain.
    And the fluid is full and red correct?
      Yep
      R.I.P Linsey Nelson
        TV cable adjusted properly?
        Nick
        88 Colony Park LS
          That I dont know...Thats what I think is the problem...But I dont know where it is??
          R.I.P Linsey Nelson
            I'm sure one of these guys will chime in with better info, but it's located on the throttle body. It should be a cable with a bushing on the TB. The bushings go bad from time to time, and could potentially waste teh trans.
            Nick
            88 Colony Park LS
              Thanks man I take a look at it ive read up on how its supposed to be adjusted in the 5.0/5.8 forum so im in pretty good shape..
              BTW is that your waggin' on the panther of the month thingy...nice ride
              R.I.P Linsey Nelson
                Nahh, that's MRLTD's wagon. Mine's an '88 Grand Marquis which isn't even on the road at the moment.
                Nick
                88 Colony Park LS
                  This was what I was thinking as I was reading here.
                    Yay...I finally made a post that contributed to something
                    Nick
                    88 Colony Park LS
                      I checked the TB and theres two cables that lead from it one goes to the firewall and one goes to this computer? near the master cylinder...Do you know wich one is it
                      R.I.P Linsey Nelson
                        Only very early 1992 models had an AOD. If you have a car made before 3/92 I think, it will have it. There will be 3 cables attached to the throttle lever, one for the accelerator pedal, one for the cruise, and the one on the opposite end of the lever is the TV cable that will go down to the transmission. If you have only 2 cables, your car was built after 3/92 and you have an AOD/E, the electronic version. Bad throttle position sensors will make an AODE shift all kinds of funky, and so can bad plug wires believe it or not.
                          And a dirty MAF.
                            true dat!
                              i believe it is 2-12-92 was the cut off for the AOD
