keyless entry module replacement?
    How hard is it to change the module in the door?
    Do you have to reset anything other than the transmitters and codes?
    this is on a 97 gm
    70 F250 Camper Special
    77 Ltd
    81 Tbird
    85 Grand Marquis
    You dont have to change the codes at all, but I don't know where the plug in is for it, we just cut the wires off of the new one and spliced it into the old wires.
      I think crown vic/gm door are the easiest door to get apart, couple screws, and they slide straight up and out once you fish the door lever-opener handle thing thru, with a slight angle, while holding the lever in the open position.
      IIRC there is one hidden behing the handle cover, which pops off, one under the switch panel, and 1 or 2 on the bottom of the panel.
        Changing module was easy, key fobs still don't program.
        I have seen TSB on an antenna that may come loose.
        Anyone know where it is located?
        77 Ltd
        81 Tbird
        85 Grand Marquis
