5.0 w/ a carb?
    5.0 w/ a carb?
    hey guys my dad is looking at a new merc wagon. its an 88, we found it on the internet. http://www.trader.ca/Search/Details....ategory=&CAT=1.
    dad went to see it opened the hood and saw a carb. i thought that the last year of the carb was 85. 86-91 had the 5.0 efi.
    the only thing i could think of is that the engine is a 5.8. even so doesn;t it come with efi aswell?
    am i loosing my mind or am i right. there should not be a carb under that hood.
    any help would be great thanks simon.
    linky doesnt work.
    in merks, 351Ws with a carb were made in canada. The older 302s also had carbs.
    Welcome to GMN!
      its possable that it has a 5.8L witch would have a carb(you cold get a 5.8 with EFI) its also a possibility that someone did some modifying to the car. does the car have a towing package? this will help me give you a better answer. and also do a free carfax check on the VIN on the car.
        the add says that it has a 5.0 302. the engine was rebuilt by ford, has 30000 km on it. it is from alberta. (we're in ontario)
        this is what;s making me frustrated. like i said i thought that the last year of the 5.0 with a carb was 85.
        i don;t know about the trailer package. it is an LS, but a cheap one. i doesn;t power antenna, the air shocks, heated wind sheild, leather.
        any help again would be great. thanks simon
          the info also states that the car had a factory installed engine so, its possible that the owner upgraded!
            wouldn;t it be a downgrade from the efi? the 5.8 wasn;t all that good from what i hear.
            some argue that the 5.0 is the best engine ford has ever made.
            how/why would he do such a odd thing?
            i have never heard of a 5.0 with a carb on an 88.
            no clue. frustrating
              No car with a 5.8 had EFI. The only 5.8 EFI was in a truck.
                so let me get this straight, the 5.8 in the 88 wagons have a carb.
                since the add says that the car has the 5.0 shouldn;t the car have efi? the carb wasn;t an option in 88 w/ the 5.0 was it?
                the car doesn;t have a trailer package by the way marquisman.
                thanks for your help. simon
                  the 351w looks like a 302 but is about an inch wider........compare the intake manifold width to a known 302
                  scott
                    is the 5.8 w/ the carb a good engine? i always thought that the 5.0 efi was better.
                    what are everyones thoughts?
                    please and thanks simon
                      The 5.8 w/carb is better than the CV/GM 5.0 all around with the exception of lacking a roller cam. The efficiency of the H.O. 5.0 is more than the 5.8 carb.
                        ok so this is the car:
                        88 merq wagon. LS, no air shocks,no power antenna,no heated windsheild,no leather
                        it (according to the owner) has the 302. it also has a carb not efi. that car had the engine rebuilt and since then has 30000 km on it. there is 1 small patch of rust on it. near the bottom of the car. everything electronically works.
                        it is supposed to nedd new cats and the wind shield has a crack in it. the owner wants 2300$ for it.
                        so dad would have to pay for the cats/wind sheild/the saftey and the emmisions test.
                        is this car worth 2300$?
                        opinions please and thanks simon
                          like i said, i would deeply consider it since you only want a wagon. maybe try to hagle the guy too...get it dow in to the 1900 to 2000 range.
