OK the CFI pissed me off real good this time.
    And I want my damn car to run.
    Time for a carb swap. HEres the list of parts:
    Motorcraft 2bbl like GL has (220 bucks)
    some sort of fuel filter with a reulator, and a return (20)
    And I may be able to run EEC-IV ignition for awhile. Trust me on this one.
    But eventually Ill make the swap to duraspark.
    You held onto that CFI hope longer than I did... Congrats :banana:
    '80 Town Coupé
      Actually, bout the same amount of time.
        cfi is an unholy beast,lol
        Save a seal, club a liberal.
          well, I never wasted weeks trying to fix it :P
          '80 Town Coupé
            Fuck you, justin
              I keed I keed
              '80 Town Coupé
                Well CFI is the best idea for evar came up with..
                For me to POOP on.
                  Man, you guys love getting bad gas mileage, don't you? I understand the 2-bbl is a direct bolt on, but you'd get hella better gas mileage with a 4-barrel.
                  Tom, I'm interested to know how you're making the CFI ignition work with a carb. Everywhere I've read said you had to change to duraspark.
                    But that was before I messed with my car, and found that fuel and spark STAND ALONE...
                      As I recall hearing, supposedly the CFI ties into the ignition somehow. I just wonder how you're gonna make the dist work alone.
                        TPS does not effect spark curve. TFI and ECU should work independent of FI
                          I must have a diamond in the rough
                          sorry to hear its still not running Tom... would you ever think about taking it to a shop to let them check on it? It still may be something simple!
                            No fucking way.
                              Triumph rocks my socks off.
                              The 2bbl is fine.
                              Just get the 1981 T-bird carb, it's only got two vac lines you have to fuck with. I plugged one and used the other for my vac advance.
