Okay... so my headlights work... But when I try to switch on my brights.. they turn off >:0.. I checked all the fuses.. they dont look blown.. Im thinking they disconnected something when they took out all the Police crap.. Any Ideas?
Problems with my Headlights.
Check the wiring near each headlight socket. My '95 had the same problem after they took out the wig wag module. I had to replace the butt connector that they used to splice the wiring together.'03 300b MM (My pride and joy until 8/9/13 @129k)
That would be the turn signal stalk. Pull the stalk toward you and see if the blue "hi beam" indicator lights up. Do the same by pushing it forward. If it lights up in either direction, then check the power to the Light Green with Black stripe wire. There should be a connector on the right front engine compartment that is used for the wig wag jumper.'03 300b MM (My pride and joy until 8/9/13 @129k)
Hmmm I was driving around eariler and I saw a Sheriff, and looked at his car, are im guessing the side marker lights are supposed to be lit when the headlights are on... mine are not... So to put it all together..
Headlights work, selecting bright turns the lights competely off
Flash bright leaves the lights at normal state, and the side marker lights do not light up.
