View Full Version : {CARB-SWAP}Looks like time for a carb swap of my own.
Grand Marquis GT
01-23-2005, 07:53 PM
Simplified! I am going to run the EEC-IV ignition, AND my stock fuel pump and relay.
Heres where the cool part starts. I am gonig to use an 84 ford tempo fuel filter, and my return line to make for a system that is cheap regulator friendly. Hook this to a 2150 that GL runs, and coupled with my existing stand-alone cruise, I will be rockin again, more reliable than evar!!!
Ill take a pic of this filter later. Its cool!
Pirate
01-23-2005, 07:55 PM
Okay, explain how you are going to bleed off about 40 psi of fuel pressure again?
Grand Marquis GT
01-23-2005, 08:06 PM
With THIS.
http://www.grandmarq.net/images/carbswap/Picture%20002.jpg
Basically, it will bleed off the excess pressure built up the the regulator, out the oriface, and into the return line (I knew they came in useful for somethin!)
Pirate
01-24-2005, 02:04 AM
With THIS.
Is that.....legal?
(quoting the fishy guy on starwars episode I...)
Are they designed for that much pressure?
Grand Marquis GT
01-24-2005, 03:00 PM
They are originally used on a carb'd car that has a return line, an electric intank pump, and a non-feedback carb. It will work perfect.
AFAIK, The pressure was close to the 32 I will be producing.
Ifixyawata
01-24-2005, 03:35 PM
I still think that there's some sort of tie-in regarding the CFI and the TFI distributor that won't allow you to run the TFI dizzy with a carb.
Grand Marquis GT
01-24-2005, 04:04 PM
Ill try it, and see.
If it doesnt work, I will have learned. If it does, I rawk! :headbang:
Powered by vBulletin® Version 4.2.5 Copyright © 2021 vBulletin Solutions Inc. All rights reserved.
