CFI Choke Part II! :-D
    Ok, umm i know theres not much on chokes. And i was hoping any one with any information around here. Might care to give it this way.. Id hate for anyone else to have such a problem as i do with mine..
    Any one got pics of there CHOKE/TPS?
    Or Even on a really good way to set the Idel/Curb Idel.
    To me it's all the same. When RPM's go Sky High And stay there imo it's bad performance. Unless you got a racing engine.
    ANy how. thanks for all the info that will be given :-D
    O and that Meteal Washer that goes on the choke stuff/TPS is that Verry inportant? Cause i lost mine and just used to more other washer's. Any how
    Thanks agine :-D
    Dark
    And any one know what the black hocky puck thing is? on the choke?
    The name of it ), need to try and get one. but dont know what to ask for :-(
      choke thermostat
        Thanks Mang :-D, Now it would make sence that that thing be broke. seeing it wont cut off after it warms up :-D
          ill get that pic for you mang so its ideling too high now? could be the choke is not releasing cuz the thing isnt on right. also the hockey puck/ choke Tstat has some adjustment evidently Ive been meaning to experement with this. If i can fool myself into not remmebring daylight savings time untill after i wake up, im going to play with this in the morning (chilly)
            SOmething else you should check before you replace the choke thermostat, make sure its getting power. There is an electric heating element inside the thermostat, and if it doesnt get power, it wont kick the choke out.
              Cool, i will try and tell :-D will a umm test light work, or is a volt meter needed?
                Ok, i checked the umm. VOlt's with a umm. VOlT meter and a umm, test light. it didint read any volts at all. So whats that mean?
                  It means its not getting power. Check the wiring and look for a break somewhere. I'm not sure what exactly those are powered off of, most carb engines it powers off the ignition coil's power wiring but I don't know for sure. Might need to check with someone who has an EVTM or a wiring diagram to find out where it should trace back to. Make sure the ground lead is good too if it has one. Some have just a single + wire, some have both a positive and a ground that goes somewhere. I'm not that familier with Ford choke thermostats so I don't really know for certain how its set up.
                  BTW, you were checking it with the motor running, or at least the key on, right?
                    10-4 on the engine running. and key on. Umm it goes into a group of wires and i loose track of it from there due to there wraped up in umm.a bunch of tape... Grr. is there any way i can just make a hot lead off of something to run it to there?
                    O and it's a one wire... No negative.
                    Thanks agine mang :-D
                    Dark
                      here u go mang hope these help
                      more to come later I have a video for you of how the choke is supposed to work
                        Sweet. The only thing difrent is the spring.. Now i have a preety dern good idea though of how it's suposed to go on ), o looks like your missing a washer :-P
                        Ooo, and that arm there in the backon mine it's not like that iot's behind instead of on top of that other arm )
                          Well mangs, the choke still dosent want to stop choking ) untill shes been driven for like 20 milles. Or i manualy undo it.
                          When i get more time ( works killing me atm ) Ima un ravel them taped up wires to see if i see Any breaks. Umm. Do them pot boung things break easy?
                          Could i get one in a junkyard?
                          And im also gonna get another Umm temputure thingy to ).
                          Just thought id update evreyone on my lack of progress with this. LOL
                            Ok, thought id share my lil updates with yea ). So i was playing with my vic agine today. And i traced that wire that goes to the Choke T Stat. And its good all the way to the end.. The end just fyi is i belive attached to something on the Volt reg. well any ways it was broke off... ::: Shakes fist ::: So.. i wd 40'ed it And striped that wire and pushed it back down in there and put elletricale tape on it..
                            The end result was as follows
                            The Idle Actualy came down on it's on without turning it off or manualy unsticking anything.
                            The tranny Wasent makking any hard shifts any more.
                            So Yay :-D
                            Any ways i do hope this helps someone else that might have that problem.
                            And it makes since to.
                            Due to When i bought the car it didnt do that high idle crap. Sticking what ever and then all of a sudden doing it..
                              Splice the wire in, just having it shoved in the connector will allow it to come apart. Glad you figured it out.
