I've seen bellhousings from lakewood that allow you to use GM transmissions on a SBF. I was thinking F-body camaros had 6 speeds from the factory from the mid 90's+. It cant be too hard to find a decent t56 used from the yard or ebay inexpensively. I think a t56 would be alot better than a t5, not only are they stronger, but they have an extra gear. Anybody know the power limit of one of these trannys? It think it would be a pretty worthwhile swap. I'm interested to hear you guy's opinions on it. No "chevy parts in a ford" arguements here please.
t56?
t56?
My rod is glowing, my bead is clean, my middle name is acetyleneTags: None
the GM T56s use different input shafts then ford trannys. so you might not be able to find a clutch with the right splines and the right bolt pattern. Also A T56 does not nescillary use the same bellhousing as other trannys. The T56 for the 03-04 cobras is basically a ring. you can change a clutch without removing the bellhousing.
Best bet would be to get a T-56 out of a 03-04 cobra, or buy one built for fords.http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalfthe GM T56s use different input shafts then ford trannys. so you might not be able to find a clutch with the right splines and the right bolt pattern.
Its for a ford 5.0. The camaro t56 uses an 11in clutch, 26 spline input with a 1 1/8 diameter input. It has all the right specs. I'm not sure if its gonna work tho.
I guess that one was a custom TKO setup for a 5.0. IIRC doesnt the t56 and tko have some kind of simmilarity?
Originally posted by MercmarquisI guess that one was a custom TKO setup for a 5.0. IIRC doesnt the t56 and tko have some kind of simmilarity?http://secondhandracing.com/Home.aspx
FRPP has this, I bet it uses the tranny for a mustang cobra
http://store.summitracing.com/partde...5&autoview=sku
Originally posted by MercmarquisFRPP has this, I bet it uses the tranny for a mustang cobra
yeah the 2000R and the 03-04s use the same tranny.http://secondhandracing.com/Home.aspx
Originally posted by capridrifterT-56 TRANSMISSION 5.0L
M-7003-G*
. For 5.0/5.8 engine applications
. 440 lbs/ft. torque capacity
. Gear ratios: 2.97/1st, 2.07 2nd, 1.43/3rd, 1.00/4th, .80/5th, .62/6th
. 7-tooth speedometer gear
. 10 spline input,31 spline output
This is from the new moter sport catolog Hope this help'shttp://secondhandracing.com/Home.aspx
I was mainly looking at the possibility of getting a used camaro 6 speed that would be alot cheaper than a spanking new one. Unfortunetly they use a 1.125 diam input with 26 splines.
If this clutch http://store.summitracing.com/partde...5&autoview=sku
works and if I can find a bell that would adapt it on, I could run a six speed for just a lil more than a t5 and not worry about shredding the trans as much
I wonder if you could change input shafts?
Hmmmm.... how bout a supra R154 5 speed?
its stronger than a t5....
http://www.turbomustangs.com/smf/ind...?topic=70529.0
