Blaze86Vic
11-03-2006, 08:02 PM
Found these on the internet at one of the many Mustang places, and thought it would be usefull for us as well. Keep in mind they are for the mustang engines.
4.6L Torque Specs
Camshafts caps to head 71-106 in/lbs
Camshaft sprocket bolts 82-92 ft/lbs
Cylinder head bolts SOHC (two valve GT and Bullitt)
--Step 1 28-31ft/lbs
--Step 2 Tighten additional 90 degrees
--Step 3 Loosen one full turn
--Step 4 28-31ft/lbs
--Step 5 Tighten additional 90 degrees
--Step 6 Tighten additional 90 degrees
Cylinder head bolts DOHC (four valve Cobra, and Mach One)
--Step 3 Tighten additional 90 degrees
Drive belt idler and tensioner bolts 15-22 ft/lbs
Engine compartment brace bolts 15-22 ft/lbs
Engine mount to engine block bolts/studs 25-33 ft/lbs
Engine mount stud to crossmember nuts 95-126 ft/lbs
Exhaust manifold to cylinder head bolts 14-16 ft/lbs
Flywheel moutning bolts 59-64 ft/lbs
Ignition coil brackets to front cover 12-22 ft/lbs
Intake and side plates assembly to cylinder head
--Step 1 15-22 ft/lbs
Intake manifold to cylinder head bolts
SOHC (two valve GT and bullitt) 15-22 ft/lbs
DOHC (four valve Cobra and Mach One)
Upper plenum to intake 71-106 in/lbs
Intake to lower side plates 71-106 in/lbs
--Step 1 15 ft/lbs
Oil cooler to filter adapter insert
-1996 59-74 ft/lbs
-1997-later 41-53 ft/lbs
Oil filter adapter bolts 15-22 ft/lbs
Oil pan to engine block bolts
-1996 15-22 ft/lbs
-1997-later
--Step 1 15 ft/lbs
--Step 2 Tighten additional 60 degrees
Oil pick up tube to main bearing cap nut 15-22 ft/lbs
Oil pick up tube to oil pump bolts 71-106 in/lbs
Oil pump to engine block mounting bolts 71-106 in/lbs
Thermostat housing bolts 15-22 ft/lbs
Timing chain cover bolts 15-22 ft/lbs
Timing chain tensioners and guides 15-22 ft/lbs
Valve cover bolts 71-106 in/lbs
Vibration dampner to crankshaft bolt
-1996 114-121 ft/lbs
-1997-later
--Step 1 66 ft/lbs
--Step 2 Loosen one full turn
--Step 3 36 ft/lbs
--Step 4 Tighten additional 90 degrees
Water pump mounting bolts 15-22 ft/lbs
Water pump pulley mounting bolts 15-22 ft/lbs
Wheel lug nuts 85-105 ft/lbs
4.6L Torque Specs
--Step 1 15 ft/lbs
-1996 59-74 ft/lbs
-1996 15-22 ft/lbs
-1997-later
--Step 1 15 ft/lbs
-1997-later
--Step 1 66 ft/lbs
--Step 3 36 ft/lbs
