I invite you to
    I invite you to
    This linkyhttp://www.edelbrock.com/automotive/7121pp.html
    and this linkyhttp://www.edelbrock.com/automotive/7166pp.html
    Cool 'EH?
    2008 Mercury Grand Marquis GS Bone Stock
    The modern definition of "racist" is "someone who is arguing with a Liberal".--updated Peter Brimelow quote.
    That is all good and fine, but check this out:
    http://www.airflowresearch.com/dyno/ford_dyno.htm
      I am from the school of Torque. Those don't even get 400#'
      and those are smal block capolas
      Bah Humbug!
        Then why post the 302 link dude?
        Did you miss the 465 ft lbs @ 5500 rpm's of the 347?
          Cause most of you guy like little engines!
            Did you miss the 465 ft lbs @ 5500 of the 347?
              OOPS! Im the :asshat: now! :coocoo:
                I am all for big blocks, but you need a bigger budget, you need to be making enough power to overcome the weight issue, and be able to put the torque to the ground.
                  www.thumperoforangepark.com
