Do I need a new rear end?
    Ok People.
    I have a 2004 Grand Marquis-Black. Will post pix soon.
    I have added a K&N air filter, PI zip tube and dual exahust.
    I imagaine HP is up near 250HP from stock 224HP.
    Have 30k miles on car. Tires are in great shape-Michilens.
    When it is wet out, right rear wheel spins more now then b4 mods.
    What should I do? New tires? Which ones? Different rear end? When it is wet out I do not get on it off the line. What is it going to be like when it snows?
    What do ya'all suggest?
    Lsb532004@sbcglobal.net
    Thanks
    Len B
    2004 BLACK Grand Marquis
    ALL BLACK -no chrome-balck front
    Legal 3 window tint-K & N filter-PI Zip tube
    Front & rear Merc God Head Badge mod wind & Rain -window reflectors
    Goodyear Triple Tred tires
    Better tires for one. The Michelins on your car are most likely designed for long term wear, and do not perform as well. You could install a track lock differential so that power goes to both rear wheels more evenly, but when you spin both tires in the rain or snow, you're gonna lose it a whole lot more quickly. Does it still have the stock 2.73:1 RAR? If so, and you are spinning them that easily, it is definitely time to look into some much better tires.
    :worship: Aeros r00l.
      Yeah, my michelins lasted 4yrs. Great longevity, but they sucked in the winter.
        Yeah start with tires then work up to taller gears and trac loc. My dads 03 GM came with michelins. They sucked ass, horrible traction, horrible cornering, and we only got 35k out of them. The tires that cars seem to come with I have found out usually suck.
          thanks
          I will check into that
          Len B
            thanks all
            I will look into that
            Len B
              Also, dual exhaust is good for 10hp, K&N is good for zero HP.
              Tires are the number one most ignored performance upgrade. You can really make that car a performer just by changing tires. My suggestion, try these Goodyear Tires.
              http://www.goodyeartires.com/eagle/eagleRE_innov.html
              My Motorsports instructor just put a set on his Maxima, and said it made it feel like his race spec Miata.
                Yes, better tires = good. If it does not have the electronic traction control, I'd also consider a traction lock and better gears, probably something like a 3.27 or 3.55. I wouldn't be surprised if you have a 3.27 in there already. If you have electronic traction control, a traction lock unit in the rear wont work properly with that system, it'll just confuse it badly.
                  I have 2.73's in my car, and since going with a wider tire it's a lot harder to spin. I imagine my wheels are heavier than stock (probably not by much) so I'm sure that contributes too.
                  I could be wrong, but I thought the single exhaust cars had 2.73's in them.
                    I believe you are correct on the 2.73:1 RAR. Also sounds like an open Differential. I installed General 255/55R16s from tirerack and made a HUGE improvement. These are a performance tire though but with stock tires I could spin them both loose at 4000RPM in first up through 2nd gear. Not with my wider tires. Otherwise, Definatley install a trac-loc LSD. That will help immensely as well.
                    1997 Grand Marquis w/ 126400
                    TOO MANY MODS TO LIST WITH ONLY 5 LINES OF SPACE. VISIT MY SUPERMOTORS PAGE FOR MORE DETAILS
                    http://www.supermotors.net/vehicles/registry/15008
                      Ive got the same problem. If i punch it from a stop i just spin. i must need better tires.
                        LOL. Mine spin from a dead stop too. How about you get better tires and give me yours
                          You know how much shipping would be?
                            Much less than the tires.
                              the toyos that we had on Vicky were pretty good we used to take 15mile an hour curves at 45mph ....!I don't recommend it!!!by the way lol we allmost got a ticket
