heat prob
    heat prob
    wtf? my 2dr does not heat anymore! i cant figure it out, i changed the core last year but, the temp control lever is kinda hard to move. when on the vent position, a burst of heat comes out then it goes cold again. im so confused, why is it doing this? :confused:
    is it also possible that there is air in the cooling system?
    pull the vac hose off the blend door and see what happens
      the thing is that heat does not come from any of the vents, defrost, or floor! i can hear the main door open in the box where the heater core is. i can always figure out shit like this, why am i stumped?lol
        first make sure that the cooling system is full
        second replace the thermostat if it's been a while
        third check the heater core and make sure it's not clogged
        check the heater control valve under the hood, it may be rusted shut
        if none of the above help, check the blend door and make sure it is working
        good luck
        scott
          for the hell of it, ill tell you what iv replaced
          -heater core.
          -fan.
          -t-stat.
          -speed resistor.
          -coolant.
          actually i found one vac motor by the ash tray with a broken vac conection, is this a possible cause?
          thanx in advance.
