My Temp gauge doesn't work. It reads negative and only moves a little when the key is turned. Never moves when driving. Which sensor is it on the intake? Is it possible the gauge is bad?
Temperature Gauge
Temperature Gauge
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Tags: None
Id check the connection at the sender, then replace itPete ::::>>> resident LED addict and CFI defector LED bulb replacements
oohh!!! I didnt think it would be a single wire sensor. Those kind you can pull the wire off the sensor and ground it to the block with a nail or something metal. If the gauge is working, grounding the wire should make the needle peg on hot. If it does, the sensor/connection is bad. If it doesnt, the gauge or its wiring is bad.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
