oil leak!
    oil leak!
    this is in regards to my 91' GM LSS, this morning when my bro started up the car it started reving high and the rpm's did not kick down one bit, then i noticed oil comming from somewhere from the engine around the passenger side by the motor mount. is there a oil pressure sender unit around there or what could of blowen? i have never experienced this problem before. the car runs pretty good still, it jus has a high idle now and is spraying oil on the exaust manifold. opinions would be great, thnx in advance.
    Transmission cooler lines run through there, and valve covers commonly leak, but I can't think of any obvious sources of engine oil which would spray in that area
      ok, now im really frustrated...wtf could be wrong here? i heard of oil senders spliting and stuff but, i cant remember witch side its on.
        oil pressure sender = drivers side
        '80 Town Coupé
          it's probably a leaking valve cover gasket.....theres nothing else over there to leak........the cork gaskets get rock hard, and then the oil passes thru.........replace em with felpro permadry gaskets
          scott
            now this is somethin to laugh at, lol...it turns out that the oil filter was a bit loose! i cant figure out why considering that i did the oil change 2 months ago. the oil thing is fixed but, also i did a comp scan on this car and it gave me 2 codes, one was for a coolant temp sensor and another for the EGR valve. i replaced the sensor and EGR-potentiometer. i did another scan to see what happens, and the temp sensor is code is gone but, the EGR is still being a bitch(the code reads as the "EGR isent opening properly" and i was wondering if the vac solonoid is the culprate? what else could be wrong?thnx ind advance.
              but.... the oil filter isnt on the passenger side :coocoo:
                EGR and oli leak
                It was probably squirting oil across to the other side of the engine, under the car...
                I just went thru all of what you going through with the EGR... There is three sensors or what ever that has to do with the EGR... There is the EGR plunger valve, that lets the EGR open and close.. it is mounted to the front of the EGR with three bolts.. then there is a vacume vlave that is mounted on the front of the intake plenum, just to the left of the EGR.. (The vacume hose from the EGR goes to it) Then there is the EGR itself... It could be bad.. hook up a vacume device to it, and see if it opens and closes... (You can close it to the point the enigine starts to die) The other thing is, take it off, (the EGR) and make sure it isn't all gummed up... if it is clean it with some carb cleaner.
                  the EGR and the plunger(what i call a voltage potentiometer) have jus been replaced so im gonna look at the vac solinoid to see if its the bitch! and the oil that was leaking looked like it was flowing around the seam of the oil pan and then the fan was throwing it around.
                    I see the oil problem was solved.... but I was going to say that my 302 leaks oil from the back of the intake manifold and burns back there. And I probably have leaky valve cover gaskets.... but I only have to add a quart to mayber a quart and a quarter between oil changes, and the only oil that I can see/smell burning is in the engine compartment, my exhaust has given me no signs that abnormal ammounts oil are burning in the cylinders.
                    And on EGR issues, a few of years ago (when my brother still drove it, and when I just first started driving it) mine used to get deposits of carbon crap built up in it, holding the plunger open. That is easily fixed with a vacuum pump and an air compressor. Strangely though, that hasn't happend since maybe my first year of having a driver's license... sometimes I wonder if it's because I spend a lot more time at WOT than my bro did... but I don't know if that would really effect EGR valve carbon deposit build up or not.
