Wheel studs?
    Wheel studs?
    Well 2 of the studs on the rear of my 89 merk broke. Im no mechanic by any means so if this is a stupid question.
    Anyway i want to replace all the studs. I took the wheel off, took the drum off. Now how the hell do i get off the piece that has all the studs in em?
    1999 CVPI
    Old Rides
    1988 Ford Mustang GT (trickflow stage 1)
    1989 Mercury Grand Marquis LS (5.SLO)
    1989 Ford Thunderbird SC (3.8 Supacharged)
    That's the axle.... remove the diff cover, pin bolt, pin, then push the axle in and pull the C-clip out. The axle will now come out.
      You gotta remove the axle to change studs?
      '95 Ford Bronco XL -
      sigpic :rebel:
        That was not part of the question. But yes, I believe you can change them without removing the axle.
          so how can i do so
          1999 CVPI
          Old Rides
            drive the broken stud out with a hammer
            now get a bunch of big washers and tighten the lugnut to pull the new stud into the axle......impact gun makes the job alot easier
              Yup, what he said. I snapped one and had to do the same thing. I'd suggest grabbing a couple old lugnuts because you might destroy one or two pulling the studs in. 1/2"-20 is the thread and size needed.
                Use lots of penetrating oil or just plain oil to lubricate the threads and the nut when installing. And make sure to use the FLAT side of the nut against the washers (or a larger bolt) when installing them like that.
