Speedometer Calibration
    I knew how to do this on my 88. Is it any different for the 96? I went from a 225/70 R15 to a 225/60R16 (.86 inches shorter) The speedometer seems close in the city, but on the highway it's off for sure. What's the process?
    "Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
    www.myspace.com/nascarmechanic
    At 60mph, it should only be reading around 1.7mph too fast. I'm not sure how to go about recalibrating it, but if it's too much hassle, I'd just live with it, personally.
      Yeah that is not enough change in size to go to a different speedo gear. Here is a link that has helped me in the past for speedo gear selection if you ever did go drastically different. http://s95318876.onlinehome.us/liquid/speedo_gear.html
        What formula did you use to find the speedometer is only off 1.7 MPH?
          I use this one: http://www.miata.net/garage/tirecalcold.html
          -Matt
            I used this one.
