View Full Version : Force lube w/o bushing removal
Buck268
01-30-2005, 01:36 PM
I'm of the understanding that an individual or two may have done this... I'm curious how you got the tap to cut a thread. Am I just being a pussy and need to drill deeper, or did you cut the tap so the threads start less shallow? I'm a little worried, as I bought a new housing to avoid the problems associated with R&R of the bushing. Any thoughts?
Buck268
01-30-2005, 01:52 PM
OK, well I got a tiny bit of thread cut... Enough to twist the brake line adaptter fitting into place... But its hardly secure. Will using some RVt sealer be enough? I dont use that stuff much so I dont really know its limits... :slug:
Buck268
01-30-2005, 02:38 PM
Solved. Cutting disc to a regular style tap = bottom tap :)
texasvic
01-30-2005, 05:19 PM
Man I should have done that with my 3.73's.
Buck268
01-30-2005, 07:52 PM
There is no requirement to do it with 3.73's unless maybe your a circle track racer, or like to do a lot of top speed runs... I only did it because my car will be seeing a LOT of highway miles next year (10hr trip between school and home, if this transfer happens).
That said, if you want to do it, its not difficult at all, you needn't even remove the bushing to get it done ;)
texasvic
01-30-2005, 08:05 PM
I do quite a bit of highway driving, though not as much as you wil be. So far so good.
Yeah I didn't even think about that when I did the install. If I do decide to go ahead with the mod I'm sure I'll be asking you some questions.
Buck268
01-30-2005, 09:56 PM
I'm sure I'll do my best to answer :)
