I have had an exhaust leak at the manifold in the P71 since I got it, only now did I look into it. There is a bolt MISSING at the rear of the head, just plain gone! What size are the bolts that hold the manifolds to the heads? I'd like to make it simple to go to the hardware store and get it fixed ;-)
Manifold Bolts
Manifold Bolts
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Tags: None
Not sure on the bolt size. but if yours is anything like my 97 a bolt is not gonna do you any good. on the passenger side rear exhaust port both bolts broke off flush with the head. the bolts have not been touched since originally installed.http://secondhandracing.com/Home.aspx
