are 98 p71 clusters a direct fit?
    hey mangs I have a 98 p71 cluster that I pulled a few monthes back I'm planning to put it in my brothers 2002 crown victoria is it a direct fit?
    Also is there a way to fix the transmission selector string I cut it by mestake when I pulled it out thanks guys
    If the shift indicator is like the older ones, you can just take the other cluster apart and pull the indicator and cable setup to transplant it. Done this on a few old style box gauge clusters. No idea if the clusters are a direct swap, but I'd imagine they are. Whats the difference on the police vs non-police clusters on a newer car, the speedo? I thought newer cars had a 120 or so speedo from the factory?
      Yes, it is a direct fit.
      Here are some pics on how to remove the cluster. Be sure to replace all the of cluster's bulbs while you have it out.
      The 2003 Marauder 300A F.I.T #003
      The 1998 P71 Jinbei. SOLD!
      The 2001 P71 (Flying Snow).
        same for floor shifter equipped panthers?
        2005 Legacy GT *13.5 @ 96MPH*
        2003 Mercury Marauder *Totaled*
          shut up! yea yea yea we all know yer cooler than us.. no need to rub it in..
            LX sport also have floor shifters d00d.
              just wanted to let you guys know I installed the p71 cluster then tested it It did not work the only thing that worked was the gas guadge when I hit the high beams the whole cluster went dark.
                That's not good. Wonder if the pins are difrent.
                  Over a year late - but sounds like the cluster wasn't actually from a '98.
                  98-02 analog pinouts are the same.
                  -My Homepage, Panther info & FAQs-
                  My Mint 96' Mercury Grand Marquis LSE -
                  Modifications
                  Click My Merc for more Pics!
