PDA
View Full Version : gabegt90's timing chain service
gabegt90
12-31-2006, 11:14 AM
friday I went to scotts to get my timing chain done as the gasket was pissing coolent. Gadget also helped he was there for the weekend It went pretty well
I did timing chain gasket new timing chain, new water pump , valve cover gaskets valve covers that I painted. egr cooent hose pipe to core hose and fixing the ground strap to the o2 it broke when me and mike changed the intake gaskets. also I did new battery cables. I will post 2 pages of pics. enjoy
I have to load them all again as closed the page without loging off of photobucket give me an hour
gabegt90
12-31-2006, 11:29 AM
pics
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006001.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006002.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006003.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006004.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006005.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006006.jpg
one of scotts heaters in the garage
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006007.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006008.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006009.jpg
the vw that scott is working on gadget calls it the hitletmobile
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006010.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006011.jpg
scotts air compressor
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006012.jpg
gadgets s10
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006013.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006014.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006015.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006016.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006017.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006018.jpg
the towncar used for parts you will noticed were the sections have been cut out for gadgets rust repair
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006019.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006020.jpg
part2 later
88Vic
12-31-2006, 04:00 PM
My freind had a Cabriolet kinda like that, except his is dark green and some limited edition, called Etinae Auigner, or some shit like that. And does that S10 have the 4.3L HO Vortec V6?
Lincolnmania
12-31-2006, 04:08 PM
no more leaks mang?
gadget73
12-31-2006, 04:14 PM
Its a 4.3 Vortec V6. They didn't make an HO version, this one is 175 hp. All stock, 143k miles, new trans at 130k. Runs fine, no major problems. Installed ball joints on one side and a fuel filter. Ran out of motivation and didn't bother with the other side. They aren't as bad on that side, barely any play. I'll deal with it later.
gabegt90
12-31-2006, 04:19 PM
no more leaks mang?
just little drops coming from the bottom pump gasket nothing a little rtv can't fix
Cable Guys FGMQ
12-31-2006, 08:23 PM
Nice work.........
Lincolnmania
12-31-2006, 09:51 PM
little drops should not be......i sealed the crap out of it, you saw that........just make sure it's not just leftover antifreeze dripping off
88Vic
01-01-2007, 01:44 AM
They did make a HO version of the 4.3, but I guess they only put em in Blazers. I know someone who has one, it moves pretty quick.
gabegt90
01-01-2007, 11:21 AM
your probley right scott mabey just left over coolent
gabegt90
01-01-2007, 12:17 PM
part 2 of pics
gmgt
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006021.jpg
tom's vic
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006022.jpg
scotts towncar
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006023.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006024.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006025.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006026.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006027.jpg
new chain
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006028.jpg
old chain
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006029.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006030.jpg
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006031.jpg
beer holder
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006032.jpg
blue valve covers
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006035.jpg
my mom's liberty in the backround
http://i108.photobucket.com/albums/n14/gabegt90/timing%20chain%20cover%20dec%2029th%202006/timingchaincoverpicsdec292006036.jpg
trife86
01-01-2007, 12:24 PM
what was wrong with the old chain? Besides being dirty it looks ok
gabegt90
01-01-2007, 12:50 PM
My car was pissing coolent from the timing chain cover gasket also the chain was a little streched so I figured I mite as well put a new chain in anyway
gadget73
01-01-2007, 11:29 PM
It had slack, not huge amounts, but over spec. Silly to not replace it while the timing cover is off, they're so cheap its worth it.
Lincolnmania
01-02-2007, 06:22 AM
yes silly not to replace the timing chain and gears while the timing cover was off......the double roller set from advance was like 24 bucks..
Grand Marquis GT
01-02-2007, 10:04 PM
Did you advance the cam, by chance?
Lincolnmania
01-03-2007, 05:04 AM
i havent advanced the cam on a lopo yet
mrltd
01-04-2007, 05:49 PM
NIce beer holder....about all those things are good for...
gadget73
01-04-2007, 09:41 PM
I dont know if advancing the cam on a lopo would do anything useful. It moves the power band downward, and its already at a fairly low RPM. I'd imagine it would just make it run out of breath even faster.
PatFromJersey
01-04-2007, 10:35 PM
Nice work there Scott. :cool: Man, I can't believe how nice PA is. Must be nice to have so much open air around your place. When I win the lottery, I'm going to have alot of open space around my place. :2up:
interceptor1985
01-04-2007, 11:06 PM
I saw that too damn your lucky! I cant find ANY PLACE for my car's right this moment I have four right out side and I just know I am going to catch hell for it....I Hate this place you guy's have NO idea......
Blaze86Vic
01-04-2007, 11:23 PM
Advancing the cam increases top end HP.
gadget73
01-05-2007, 12:37 AM
No it doesn't.
http://www.camcraftcams.com/camshafttuning.htm
Mercmarquis
01-05-2007, 03:25 PM
You're thinkin of retarding it.
mrltd
01-05-2007, 03:28 PM
Advancing and retarding does not increase HP. It moves the power around the RPM range. I would leave the lopo alone.
