As the winter rolls on, and ThatOneGirl and I start talking about the upcomming Spring's projects, we come to the focal point, time and time again. Her AODE is SHOT. It does all the standard things, slipping into and out of gear, wobbles through gears. So the plan of attack is this. In the Spring (or sooner if it dies completely) we're gonna get a Jasper re-man for it. When we do, I'ld like to spruce it up a bit, without voiding Jasper's warranty. Would a 2800 Stall converter and/or a shift kit void it? At the same time I'ld like to do the rear-end gears as well. Y'all seem awfully fond of the 3.55 Trac-Locs.. is that fairly straightforward install? Or should I seek a guru? Will the different gears mess with the Speedo? As I said, this is pre-prep work, so Im not lookin for full concrete results just yet, but tryin to feel my way into the project.
The Admiral
The Admiral
