It only goes away when I pull the #12 fuse under the dash. That controls all the power accessories, lighting module, seats, windows, power locks, mirrors and stuff like that. Every day the battery is drawn down. I'm sick of this and can't find the issue. THe only two things that do not work are the passenger rear window regulator and the drivers front door jamb switch. Any more ideas or testing techniques?
Dang Electrical Draw
"Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
www.myspace.com/nascarmechanic
Tags: None
Is it something silly like a glovebox light or trunk light being on? Do you have a trunk sucker that might have a stuck switch? What happens if you unplug the DS door switch? It might be shorted inside and causing just enough voltage leak to drain the battery slowly.86 Lincoln Town Car (Galactica).
