PDA
View Full Version : Trans Question...
Mr. Land Yacht
01-04-2007, 01:45 PM
I hear people talking about "wide ratio" AOD's.
or making their stock AOD have a "wide ratio"
what does that mean?
is it a bigger OD gear or something?
what are the benefits?
-Colin
88MercWagon
01-04-2007, 02:30 PM
It's a different set of pullies and bands that give it lower [numerically higher] 1st, 2nd and OD gears. If I recall correctly it is the same gear ratios as the 4R70W
Mercmarquis
01-04-2007, 02:51 PM
Yessir, 4r70W is very close to the AOD. I think you can pull the gear set from a 4r70w and make your own wide ratio AOD.
interceptor1985
01-04-2007, 02:57 PM
The shaft from the AOD-E is stronger then the older AOD.I haven't built my own AOD yet but I want to someday I think it would be fun.
DuceAnAHalf
01-04-2007, 03:06 PM
A wide ratio AOD is an AOD with the gears out of a 4R70W. The transmissions are basically the same, but the 4R70W has lower gearing and stronger parts, and it is fully computer controlled.
Mercmarquis
01-04-2007, 03:07 PM
I was gonna do that with my blown AOD I had lying around. I figured having $15 in my pocket was better that havin a blown transmission in my garage waiting till I have enough $$ to build it, so I took it to the recycler's.
Mr. Land Yacht
01-04-2007, 03:49 PM
so, if I wanted to make my AOD into a wide ratio AOD, how much would it cost me to have it done?
let's just say I wanted 1st and maybe 2nd gear done, but leave OD alone...how much? any idea?
BTW, what are the gear ratios of the AOD and the 4R70W?
interceptor1985
01-04-2007, 04:23 PM
Ok somebody make a parts list with part number's and even a price. That would settle most of these questions. Thank you
Mr. Land Yacht
01-04-2007, 04:37 PM
yes it would. thanks.
phayzer5
01-04-2007, 04:51 PM
Here's the pics I took of the pages from my FRPP kit manual when it arrived from Summit:
Roughly an 18% increase in gearing in 1st, and 5% increase in 2nd and 4th (OD). 3rd is the same direct drive 1:1 ratio.
http://www.phayzer5.net/images/WRK-page1.jpg
http://www.phayzer5.net/images/WRK-page2.jpg
http://www.phayzer5.net/images/WRK-page3.jpg
mrltd
Uh, you can't NOT "DO" overdrive. It's all or nothing. The 4r70W OD band is far better than the AOD one anyway. There is tons of info on this subject. Spend a few minutes and do a search..
interceptor1985
01-04-2007, 04:54 PM
Is there a good Carbon clutch pack too?
Mr. Land Yacht
01-04-2007, 05:50 PM
I'll try to search and see what I find.
DuceAnAHalf
01-04-2007, 06:12 PM
For clutches go with the Alto Reds, for the bands there are Kevlar bands but those are for full race transmissions.
Mr. Land Yacht
01-04-2007, 07:50 PM
so, what would I need put in my AOD from the 4R70W trans?
I don't know a whole lot about transmissions.
How much would something like this cost ot have done?
my entire trans rebuild cost me about $1100..I wouldn't want to spend that much again unless the trans gives out.
one more thing:
if you put in the 4R70W gears, what sort of ratio would you have for first gear?
meaning: I have a 3.55 rear end, if I put in the 4R70W stuff what would the ratio change to for 1st and 2nd gear?
DuceAnAHalf
01-04-2007, 08:43 PM
one more thing:
Justin got his built for $800 on top of the $500 kit from FRPP, I got my C4 for $1250
mrltd
01-04-2007, 08:45 PM
I cannot say what i paid for my WR-AOD because of how cheap it was. :)
gadget73
01-04-2007, 09:10 PM
Here's the ratio chart
http://www.grandmarq.net/vb/showthread.php?t=5953
88MercWagon
01-04-2007, 11:56 PM
:rx: :rx: :rx:
phayzer5
01-05-2007, 07:27 AM
The FRPP kist came as an assembled unit that you pretty much just drop into the trans. You can save quite a bit by nabbing a junkyard 4r70w and swapping parts over, but its alot more to mess with that just dropping in the assembled FRPP unit right out of the box if you can find/afford one
one more thing:
If you have a 3.55 rear end and change your AOD to a wide-ratio AOD, your first gear acceleration will feel like you have a 4.19 rear end gear, 2nd and OD will feel like you have 3.73's
:rx: :rx: :rx:
someone at my hosting company decided that I didnt pay the bill, so they suspended it. The glitch will be fixed and the site/pics back up in the next day or 2
Mr. Land Yacht
01-05-2007, 04:16 PM
do you guys really think it's worth the money to have it done?
I paid $1100 to go from 2.73's to 3.55's and I don't regret it for a second!
do you guys think doing the Wide Ratio AOD would be nearly the same difference?
I can't imagine what it would feel like to essentially have 4.19's for 1st gear and 3.73's for second.
for those of you who did it...was it really worth the money you paid?
phayzer5
01-05-2007, 07:43 PM
Definitely worth the money. It really helps to get our big cars moving.
Blaze86Vic
01-05-2007, 08:57 PM
Yes, for sure.
mrltd
01-05-2007, 11:22 PM
Definately worth the money... It does have it's issues though. Late 1-2 shift, and gear spacing is kinda wierd. It does work well for getting the car moving and I love it.
DAMN! 1100 for gears? You are friggin Mr. Moneybags.... I paid 450 for a completely assmebled 3.73 trac loc rear with everything new in it. I paid 1100 for my car, and thought it was too much.
Lincolnmania
01-06-2007, 12:14 AM
damm 1100 for a stock aod..........all said and done mikes wide ratio was'nt much more than that.......helped that i got a 4r70w core for cheap
the kit is discontinued from ford, team ford may have one left, or harvest a used 4r70w out of a 95 or newer vic, gm, mustang, or thunderbird/cougar.......mikes core came from a 97 cougar......the kit is nice cause it's got all new clutches and steels and all new parts, saves the tranny shop tons on labor........with the wide ratio you should also think about a torque convertor...what stall you want......you prob want at least 2400 with the mods your planning, for a daily driver, i like the thunderbird supercoupe convertor......it's about 2000 rpm stall, superlinc, toms vic, gadgets towny, running that convertor so far.......i know others love their 2400's
should also get a transgo aod hp kit........about 100 bucks
a overdrive servo.....they make a super a servo for 125, if u wanna go all out, but a oem a servo is fine
a deeper pan is a plus......more fluid so it stays cooler
and a must an external transmission cooler.........the higher the convertor stall, the bigger the cooler needs to be
DuceAnAHalf
01-06-2007, 05:03 PM
Definatly a bigger cooler, my 3000 converter will make the fluid hit 210 degrees really fast.
Nathan in MI
01-06-2007, 05:33 PM
Is a wide ratio AOD something that a mere mortal can install himself, or does it require advanced knowledge of auto trannies and the AOD in particular?
88grandmarq
01-07-2007, 08:56 PM
you can use different govenors to adjust the WOT shift points. using the low speed shift govenor, with the wide ratio gears, yields approximately a 5000 rpm 1-2 WOT shift and a 4800 RPM 2-3 WOT shift point, which works perfectly if you using a stock HO or mild cam. using a high speed govenor yields a 5600-5700 RPM WOT 1-2 shift point, which may be more suitable for for higher reving cams.
I also highly recommend a lentech valve body for the wide ratio trans. they do some sort of modification to the 2-3 shift that makes it longer to take full advantage of the increased gear ratio. I noticed a huge difference in my car after installing a street cruiser valve body from Lentech.
Mr. Land Yacht
01-08-2007, 06:37 PM
hmm...I'm seriously considering this, but it wont be done for a LONG time.
since I just had my AOD rebuilt when I bought it(Nov.'04), it would be foolish to rebuild it again so soon.
I already plan to get the B&M 2000 stall converter. I thought about getting the 2400 stall, but it's double the price!
I also plan to get the Baumann shift kit.
Mr. Land Yacht
01-08-2007, 07:10 PM
I found a 4R70W trans for sale in MI for only 300 bucks and it only has 23k miles on it!
I might just buy it for now and do the work later...
sound like a reasonable price? sounds good to me.
DuceAnAHalf
01-08-2007, 07:30 PM
Another option is to find a 4R70W out of a newer 5.0 explorer and either go with a full manual valve body, a baumanator controller, or chance it with an AODE computer and a lotta luck.
phayzer5
01-09-2007, 06:14 AM
When your in the market for a converter, check out this guy on ebay (http://search.ebay.com/_W0QQfgtpZ1QQfrppZ25QQsassZmorandon). If he doesnt have any listed for an AOD, call him at 727-944-3904 to get one made with whatever stall you want, $140-150 or so shipped. Cool guy and a cheap, good quality converter.
gadget73
01-09-2007, 08:37 AM
300 bucks for a parts tranny? thats nuts.
Mr. Land Yacht
01-09-2007, 11:13 AM
doesn't matter anyway..he already sold the tranny. I'm relieved.
but yea, I'll ask that guy about the Torque Converter...thanks Phazer!
I should really get the 2400 stal 'cuz with the E303 cam and 1.7 roller rockers, my total lift should be around .530".
so, that might change the powerband of the cam just a bit...2400 stall would be better than 2000 stall...
DuceAnAHalf
01-09-2007, 04:13 PM
Morondon is pretty good. My brother used one of his loosened stock converters for a while. Still have it laying around.
