Im wanting to put PI heads and intake on my 92' M75..Its a old romeo built engine..Just wanting to know if its do-able...If not....Time to do a 5.4 swap
PI Heads and Intake
The only way to run a AOD behind a 4.6 is to use a 91 or early 92 block with the AOD bellhousing bolt pattern. You cant run a 5.4 with an AOD since there are no 5.4 blocks that bolt to an AOD. You could run a newer AODE/ 4R70W behind either a 4.6 or a 5.4 if you get the proper trans/computer.http://secondhandracing.com/Home.aspx
Originally posted by 88VicWhen I said AOD I meant the stock trans in his car. I thought it was an AOD like the boxes have. What do Areos and whales use, just a regular 4 speed auto?http://secondhandracing.com/Home.aspx
In that case it should be the normal 4.6 bellhousing so you can use whatever mod motor you wanthttp://secondhandracing.com/Home.aspx
