Dynomax Super Turbos
    Quick question:
    What diameter mufflers should I get -- the 2 1/2" inlet/outlet or 2 1/4" inlet/outlet? Does it really matter?
    This will be running with cat-less mustang H-pipe. Thanks.
    Justin
    2 1/2" The Mustang offroad H-Pipe should be 2 1/2"
      Originally posted by Mercracer
      1 1/2" The Mustang offroad H-Pipe should be 1 1/2"
      I meant 2 1/2".
      Sorry. Fixed original post.
        Is there a certain size (length/width) that any of you guys are running? I'm going to be ordering from Summit. Don't know which part number to choose.
          On my t-bird (all that mustang crap is direct fit, mostly) I used 2 1/2 inch mufflers. Where I made the mistake, though, is I got offset/center mufflers. I need to get Offset/offset to run tailpipes.
            That's what I was watching for when I was looking at summit.
            I'm pretty sure these are the ones I'm getting: Part #WLK-17734
            Justin
              good muffler choice! Scott's towncar sound beautiful with those mufflers..
                Thought of another question:
                -- What diameter exhaust should be run out back behind the mufflers? I don't have the car here so I don't know what stock pipe size is (2 inch?). I was thinking of running 2 1/4" out the back after the mufflers and having them hidden just behind the bumper with a slightly turned down angle.
                Justin
                  like this?
                    i run 2 2.25" midpipes napa part number 43281 with 2 napa 4670 midpipe flanges
                    get two dynomax super turbos part number 17732
                    either have 2 custom 2.25" tailpipes bent and installed, or use 2 stock tailpipes with two reducer bushings (sorry i dont have the part number)
                    also you will need 2 o2 sensors with longer harnesses.......what i did was save the plugs off the old 02's and i spliced the old plugs to these new sensors with solder and shrink tubing
                    bosch (from pep boys) bio 13953
                    scott
                      Re: Dynomax Super Turbos
                      Originally posted by monterey1962
                      Quick question:
                      Justin
                      It might be a good idea to get a 2 1/4 off-road H-pipe instead....Hooker sells one through Summit, but it might only be available now through an entire exhaust kit (not a bad idea, actually, as you also need the Cat-muffler connector pipes)...I think the exhaust system kit runs around $167....minus mufflers.
                        Too late. I already have two 2 1/2" H-pipes setting in the garage. One w/ and one w/o cats.
                        Justin
