View Full Version : Dash Light / Climate Control Light
MrMarquis
01-20-2007, 06:46 PM
Howdy; gots questions.
Ever since I was hit, my dashboard gauge light and climate control console lighting will flicker in and out. I haven't checked the fuses yet, it may be a fluke...But I was just curious as to what y'all thought. Maybe a wire was knocked loose on impact?
Another thing that started up. My Viper keyless entry and remote start system stopped working. I thought it was just the remote battery at first; but the locks are supposed to work automatically when I start and turn off the car...And they don't fire. I haven't a clue how the system is wired; so maybe someone would know if they are sensitive to collision shock?
Thanks. :merk:
Dave84
01-20-2007, 07:20 PM
is there any kind of reset buttion do you know? and the dash light's im not to sure about
gabegt90
01-20-2007, 10:08 PM
mine does that too sometimes when I'm driving at night the cluster will dim for a little bit I think it's because of my orgrinal altenator
MrMarquis
01-20-2007, 10:14 PM
It doesn't dim, it goes completely out; the dash and climate control...Can't see a damn thing when it does.
nitroracer
01-20-2007, 11:22 PM
If its all the dash related lights you have a wiring problem in there. I had a problem with my old car that would lose power entirely on corners, no lights, engine, nothing. Ended up being bad battery cables.
boXman
01-21-2007, 11:03 AM
Take out your headlight switch, I bet the plug is crispy.
I replaced the plug on mine, cuz I had no dashlights an shit. Still had no dash lights, replaced the switch and now its good.
85crownHPP
01-21-2007, 12:25 PM
yup look at that. next time it happenes, go look to see if you have parking lights. if not, its prolly the switch or a wire for the parking lights getting pinched. Try wiggling/turning the headlight switch too.
Paul_
01-21-2007, 08:57 PM
The headlight switch, and quite possibly the connector to the switch, are toast. Ford, in their infantile wisdom decided to route all the juice flowing through the lighting circuit into that switch.
If you're lucky, the connector may not have gotten fried just yet, and you'll just have to replace the switch. I also highly reccomend that you install relays for the headlights. Doing this will help prevent issues later down the line.
MrMarquis
01-22-2007, 07:43 PM
Well...I had parking lights...
So, I guess I have to go under the dash to get the headlight switch out?
Paul...Would you have a diagram or a better explanation of the relays? I'm not the most electrically-inclined person...
gadget73
01-22-2007, 10:24 PM
Might also be able to fix it by simply removing and re-installing the bulb. Sometimes the connection on the bulb gets funny. Good idea to inspect the switch connections though just to be safe.
