I really screwed up
    I really screwed up
    THe air pump was already off the 83 when I got it. tonight I took out the hoses and valves for that old a.i.r. system. I also plugged the vacuum line that went to the electrical solenoids that supplied additional vacuum to the valves on teh inner right fender. Now the car really runs like shit, so rich that EVERYTHING is black now. what the hell did I do wrong? It won't stay running, it hesitates and misfires. I'm beginning to hate this car.
    "Owning a 9-second Import is like coming out of the closet.... At first it may be surprising, but in the end, you're still gay!"
    www.myspace.com/nascarmechanic
    What is that electronic piece on the right inner fender well? It has three connectors on it, the housing is made of aluminium, it has 6 vacuum lines on it, two from the engine, two that re-attach to the unit, and two that go to the a.i.r. system hose mess right next to it. With the main vacuum hose removed from the unit, the car runs as described before. Plugged hose or not. With it plugged back it, it runs normal. What is this thing and how I can I delete it?
      There is one sensor over on the fender that must be connected, the B/MAP sensor. Its a roughly oval thing with a round electrical connector. If that has no vacuum, the system runs pig rich because the ECM thinks the motor is at full load. You cannot remove that sensor, its quite possibly the single most important one on an EFI system.
        That is the oddest MAP sensor I have ever seen. Damn EEC-III system. Time to find a nice intake and 2v carb. That certainly explains the rich run condition. Is there an alternative? Smaller perhaps? Can I remove all the a.i.r system stuff connected to it and just run the MAP? Time to experiment.
          Im not sure what the "thing" is... can you take a pic??? I cant picture it in my head and I was just looking at an EEC-III car under the hood...
          Yes, you can remove the smog air stuff and be fine. Only thing you should have to have is the MAP as far as i know. You'll want to keep the one that controlls your Idle kicker/choke pulloff too.
          this is the MAP demon
